Question about Theater Research TR-9500 Car Subwoofer Box Car Speaker
How many square feet do I need for a sealed box for 2 10 inch Theatre Research subwoofers
I have a alpine 6013 sub, what should i tune the port to? i listen to mostly rap if that makes a difference.
Box should be 1.2 cubic feet. port should be 13 square inches depth 16 inches and Fb/F3 will be 42/35 (Fb=port freq F3=cut-off freq
Nov 02, 2014 | Car Audio & Video
What is the cubic feet needed to build box for audioban 12
You can use this speaker in either a ported or sealed box. A sealed box would be smaller, (sealed box volume: 0.5 to 1.25 cubic feet) the larger the box the more base you will get. With a sealed box your amp has to work double hard as it would in a ported box ( 1.3 to 3.2 cubic feet) You will get close to double the volume in a ported box. Tuning a ported box with the size and length of the port will determine the hertz the speaker will play at.
Sep 15, 2014 | AudioBahn AW1206T Car Subwoofer
What size should my box be for 15 inch square kicker
At least 3 cubic feet. Less if you're going to port it. There are online calculators for box and port sizes if you have the specs on your sub and the type of music you like.
Feb 05, 2014 | Kicker CompVR 05CVR84 Car Subwoofer
What r the parametric specs for the ma audio hk15x2
Fo (Hz) : 29.581 QMS : 3.965 QES : .517 QTS : .457
VAS (liters) : 147.723 REVC (Parallel-Ohms) 1 SPL @ 1 watt/ 1 meter (dB) : 90.6 X-Max Linear peak-peak (mm) 70 LEVC @ 1kHz (mH) : 1.043 Enclosure Volume (Sealed) : minimum 2 cubic feet Fill Required % : 0 3dB down point (-3dB) : 43 maximum sealed: 2.5 cubic feet n fill required: 39 at 3 dB down point Enclosure Volume Ported Vented (cubic feet) : 5.0 Vented to Hz: 35 3dB down point (-3dB Hz) : 28 Square port area Sq/In : 80 Port Length : 13" Power Handling : 2000 Watt RMS & 4000 Watt Max. Make sure to use MDF for the enclosure and use 1 inch thickness and use braces as well. This is a beast of a sub woofer. So give it the proper power it needs and make sure that your box is very solid in construction. If installed correctly and given the right power, this sub woofer is bound to put a smile on your face and rattle your bones. I hit 142dB with only one of these subs and im sure if i gave it more power i could hit the 150dB range. DON'T FORGET TO GIVE IT THE POWER IT DESERVES. Have fun dreamsystems.
Feb 16, 2011 | MA Audio HK15X2 Car Subwoofer
Kicker 8 inch l5 problem!
Possibly. Actually there are sub rings you can buy to convert a regular box over to one that will accept a square sub without cutting the whole out in your box to make it square. The airspace may be lacking a little bit.
May 20, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a 15 inch legacy sharp steel 4000w subwoofer. how much air space does the enclosure need to have? and does it matter if it's sealed or ported?
about 1.5 cubic feet for a sealed box and it does matter if its ported.. if you port it you need to find the right size port hole and length to suit the box and suit it to the most common music type you listen to..
Feb 25, 2010 | Car Audio & Video
I need to know the demensions for 10 inch subs
almost any 10 will use .75 cubic feet up to 1.25 cu ft. thats about the size of a milk crate give or take. a sealed box will give you the cleanest tightest bass. A ported box will be louder but also larger at the cost of decreased power handling ability and sound quality. If your subs are designed for small enclosures use a sealed box around .75 to 1.00 cu ft.
Jan 30, 2010 | Koiiler XM-6715 Car Subwoofer
I NEED THE SIZE OF THE BOX I CAN MADE IT FOR KFC-WF305 PLEASE ?
For just the single sub i'd recommend going with a 1.25 cubic feet sealed enclosure, made with at least 1/2 inch MDF.
Sep 30, 2009 | Kenwood KFC-WF305 Car Subwoofer
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Theater Research TR-9500 Car Subwoofer Box Car Speaker Logo
Top Theater Research Car Audio & Video Experts
xxxxxx xxx
Are you a Theater Research Car Audio and Video Expert? Answer questions, earn points and help others
