Round 2993 to the nearest hundred
Round 2993 to the nearest 100
  • 7993 Answers
SOURCE: ACME Skateboards Inc., has paid
Doesn't any body do their homework anymore? How are they supposed to learn anything?
Draw your graphs by hand or on a graphing calculator.
Think about the intersection points. (What does that mean when two curves intersect?)
Use the equation for the demand to obtain D for a particular x.
You can also determine by how much one function exceeds another for a particular value of the x variable (the graph is rather clear).
I assume you can solve a quadratic equation.
Use these hints to solve the problem.
Here is a graph. I even restricted it to the first quadrant so as not to mislead you into giving meaningless answers.
Hope it helps.
Posted on Oct 04, 2009
SOURCE: i need to round 301,421,
Well that would be... 301,500,000 rounded UP, or 301,400,000 rounded down.
BUT the second answer, 301,400,000... is YOUR answer....
The nearest hundred thousand is 400,000... hence the answer, see?
Posted on Aug 19, 2010
rw93003
SOURCE: How can I change the setting to print total the
You need to set your decimal selection to full-floating if you expect any numbers to be more than 4 decimal places.
Each time you press the DEC key it changes the decimal selection. From F to 0, 2, 3, 4 and A in that order. F is "full floating" but appears as a blank on the screen. A is the "add-mode" for currency transactions. The "A" does show on the screen if this is your selection.
As soon as the letter for the number of decimal places you want ("F" is blank just before 0 decimals) appears on the screen you are "ready to go." Problem is, the decimal indicator numbers and letters are so tiny and screen is so difficult to read that under many lighting conditions your selections might be all but invisible. They are in the upper left side of the screen just to the right of the equally difficult to see multiplication and division rounding indicator "5/4." PS If the 5/4 does not appear on your screen then you have set the round-off function to not available.
Posted on Apr 01, 2011
thehappydog8
  • 50 Answers
SOURCE: what is 27,415 rounded by
27,400 is the answer
Just like rounding your 10's
The breaking point is at 50 instead of at 5
So if the number was 27,465 it would be 27,500
Posted on Jun 23, 2011
  • 37 Answers
SOURCE: 4136 rounded off to the nearest hundred
4100
It would need to be 4150 or more to round up to 4200.
If your calculator has a function for rounding to the nearest integer, you will need to divide by 100 first, then round, then multiply by 100 again.
Posted on May 29, 2012
How to round 12.64 to the nearest hundred all that apply
Rounded to the nearest hundred, it would be zero.
12.64 is closer to 0 than it is to 100.
Oct 20, 2016 | Cars & Trucks
473075 rounded to the nearest thousand
473000
If it was to the nearest 10,000, it would be 470000.
If it was to the nearest 100, it would be 473100.
If is was to the nearest hundred thousand, it would be 500000.
Aug 26, 2015 | Office Equipment & Supplies
What is 9,246 rounded to the nearest hundred
nearest 100 = 9,200
nearest 1000 = 9,000
Apr 08, 2015 | Office Equipment & Supplies
Estimate by rounding to the nearest hundred
118+146
Round 118 to the nearest hundred. Look at the number to the right of the hundreds column. If it is 5 or greater, add 1 to the hundreds column. If not, don't add 1 to the hundreds column. Make all columns to the right of the hundreds column 0. Since the number in the tens column is 1, we don't add 1 to the 1 and make the 1 and 8 zeros, so we get 100.
We do the same with 146. 4 is less than 5, so we just change the 4 and 6 to 0 and get 100.
We now add 100 and 100 and get our estimate of 200.
Good luck.
Paul
Oct 20, 2014 | Office Equipment & Supplies
What is 82,596 rounded to the hundreds, tens, thousands, and ten thousands.
Rounded to the nearest hundred: 82,600
nearest ten: 82,600
nearest thousand: 83,000
nearest ten thousand: 80,000
Sep 17, 2014 | Office Equipment & Supplies
How can i round to the hundreds or thousands
Divide by a=100 (or 1000), round to the nearest integer, and re-multiply by a=100 (or 1000)
May 22, 2014 | Casio FX-115ES Scientific Calculator
53017 round to the nearest hundreds
The same way you would do it if the digit is something other than zero.
53017 rounded to the nearest hundreds is 53000.
Feb 14, 2014 | Office Equipment & Supplies
How to round off 41 to the highest value
What do you want to round it to? To the nearest unit, 41 is 41. To the nearest ten, 41 is 40, to the next highest ten, 50. To the nearest hundred, 41 is 0, to the next highest hundred, 100.
Jan 10, 2013 | Office Equipment & Supplies
4100
May 10, 2012 | Canon Office Equipment & Supplies
I need to round 301,421, 900 to the nearest hundred thousand can you help me?
Aug 19, 2010 | Casio MS-80TE Calculator
53 people viewed this question
jasbo
jasbo
