Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
I have no reaction from channels 1 thru 22.
Channels 23 and up to 40 are working find
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Sounds like the radio is out of alignment or the pll has failed. have the radio serviced
Posted on Sep 14, 2014
Cobra 29 cb radio not responding with 1 thru 22 channels.
is it used? if so it may have been hacked for more channels and no one finished the work.If its new send it back to cobra .its under warrenty
Feb 06, 2014 | Cobra 29 LTD CB Radio
Hi I have a mackie sr series 24.4.2.b bus miximg console in for repair,most of it is working except that the right channel output is misssing on on sub outputs 1 and 5 and 3 and 7,i do not think its...
Remember that the subs are each MONO outputs. They do not have stereo outs. They can be used as pairs like 1-2 for stereo and those should PAN with the pan control at each channel assigned to a sub.
For mono's, the left channel is the one used.
Refer to the signal flow diagram for the Mackie mixers to analyze this. It probably is on page 28 of your manual.
For the subs, you can pan AT THE CHANNELS ASSIGNED between for instance sub1 and sub2. Note these work together as odds and evens.
Jul 14, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I am using cable, no box, I want to program in the channels. The channels 1 thru 22 are already programmed but I want to add 23 thru 79 channels I can't figure it out.
The TV might have an auto programing function, which should tune in all available channels that are being delivered thru the cable/from the cable company.
Apr 15, 2010 | Samsung BN59-00455A Remote Control
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
Hello. I have one (1) XS-L1035 being powered by a JBL gts 180X 2/1 channel amp. The sub works fine if i power two(2) subs thru 2 channels BUT if I try to bridge the power to one sub the amp cuts out. Is it...
It sounds like the problem is with the amp. try using the other sub in bridged mode and see if it still turns it off. If it still turns off then its definitely the amp. In 2 channel mode you are using each channel at 4 ohms right? and in bridged mode to 1 speaker it should be throwing a ton of power on a 4 ohm load as well,it should work fine bro -its gotta be the amp
Jan 30, 2010 | Sony XS-L1035 Car Subwoofer
Auto Set Channels
1ST) see if the power is being turned off on the machine from the power source.Do you have a time screen? A screen that tells the time, is it blinking ? You could have a loose connection to the AC plug. Does the machine have a "back up" memory battery ?
2nd) Sound on only 2 channels thru VCR is a circuit problem.
Aug 13, 2008 | Zenith VCS442 VHS VCR
Universal remote codes
google search the brand and model of the remote shouldny be hard to find
Nov 23, 2007 | RCA RCR660 Remote Control
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
63 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
