Question about Keurig Platinum B70 Coffee Maker
Keurig won't prime - Keurig Platinum B70 Coffee Maker
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Lift the reservoir, then reseat it. This will clear the prime message. If it repeatedly comes back then your machine is dead. If in the year warranty, call Keurig they will ship you a replacement. Very common problem.
Posted on Sep 28, 2014
SOURCE: MY KEURIG COFFEE MAKER WON'T WORK AND IT
I had the same problem, the machine is two monthsold, and found a way to fix it. This is my second unit as the first unit failed after 14 months. Removing the resovoir and using my finger to push up on the valve that allows the resevoir to drain into the base unit always worked for me for perhaps a day. I got tired of doing this and three days ago I glued an 18 ga copper circle the end of the valve to open the valve wider when the resovoir is seated in the base unit. While it has only been 3 days so far there has not been a prime problem. I also us K-cups and the unit leaked water every time. I removed the rubber grommet on the lid and place a folded piece of aluminum foil (8 layers) that i pierced to fit over the needle that punctures cup. I then pkaced the grommet back on the needle and have had no leakage since. Hope this helps you.
Posted on May 31, 2011
heatman101
  • 43501 Answers
SOURCE: The word prime is on
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: My Keurig displays the word PRIME and won't
heatman101
  • 9 Answers
SOURCE: my platinum Keurig says to
Im a student in electronic and i would say to you some basic things:
1.Dont work long with that, that has resistors, is like a bulb, some day has to broke but
in your case, you might have little higher voltage in the input.
2.If you have a bussinness coffee , buy a good one, dont be attracted from tv spots.
3.To repair it itll cost you double, the electronic man that repair that
has to find the right electronic element. Has to see that live. or you could tell me what is burned
or exploded. if nothing of those two, you have to test the voltage output with multimetter
maybe your house voltage damage your coffee,
(in Europe 220v in USA 110v)
Do you have read the troubleshoot , that little book with your coffee maker?
Posted on Aug 25, 2011
mc1bean
  • 3053 Answers
SOURCE: My Keurig keeps saying Prime
Hello ,
      Often the pump gets air in it and does not prime correctly. It will then only pump a little water. To fix this you may need to get rough with the machine. Slamming the reservoir onto the machine will sometimes work, The shake rattle and roll method also will have the desired affect sometimes. Some have turn the machine upside down over the sink, have slapped the sides of the machine, or even shake the machine to get the air out of the lines.
      Once you do get the pump to prime properly, you can keep the pump from getting more air by making sure to fill the reservoir before it gets empty by using a pitcher to fill the tank instead of removing it and filling it.
With some K-cups, the bottom needle does not pierce the bottom of the cup if you simply place the K-cup into the holder and then close the top. Extra effort may be needed to make sure that the K-cup gets seated properly so that the water can flow through the K-cup easily. If you have water still in the K-cup when you remove it after brewing, you are having this problem.
Also here is some more information that could help as well:
Descale the coffee machine....
White vinegar is recommended, but it seems like lemon juice works just as well or even better. Also there are many different commercially sold products to descale coffee machines. One of these is a product called CLR which seems to do a great job. Some people have even used their denture cleaner to descale the coffee brewer. Dissolve a couple of tablets in water and place in the reservoir... then run the solution through the coffee machine to clean it.
Another common problem is that foil from the K-cup lid will get stuck in the needle that punctures the top of the K-cup. Like wise the bottom needle can also get coffee grounds or other debris stuck inside it. Scale from the descale procedure can also be a problem. To get the needles clean the best thing to use is a paper clip. Do not use a toothpick as that can break off inside and cause greater problems. Bend the paper clip so that approximately 1" is straight. Then insert the paper clip into the needle and wiggle to clear any debris. On some brewers the K-cup holder can also be removed, the bottom will twist off to reveal a nozzle that also has small holes that will plug up. Cleaning these holes may be the ticket to a great cup of coffee again.
Check to see if you have water running back into the reservoir when you are brewing a cup of coffee. If you have water bypassing, then you have a problem, there should be no water returning to the reservoir if the brewer is working properly. To stop this from happening there are a few things that you can do.
. You can hold your finger over the white tube in the top of the reservoir to place more
pressure on the water to flow through the needle and expel the debris from the tubing.
Take a can of compressed air like you would use to clean your computer and blow air through the tube(s) in the reservoir and also the needle(s) to clear dirt debris and water from the machine. This process may make a mess so be sure to have the machine is a place where the mess can be cleaned up easily. Some have even used a large tire type air compressor out of desperation, and report that it does work. I would use great care with this method and shoot the air in very short bursts.
Hope this helps......... Mike from fixya.
Posted on Aug 29, 2011
I keep geting the prime message on my machine. Machine won't run when message is on. Any suggestions?
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 05, 2011 | Keurig B60 Coffee Maker
My keurig is flashing NOT READY and AUTO OFF SET and won't brew or even turn off
heatman101
Sep 02, 2011 | Keurig B60 Coffee Maker
Won't **** up water,haven't used in awhile
heatman101.,
Aug 27, 2011 | Keurig B60 Coffee Maker
It's like my pump won't pull water out of the tank. Any way to fix this?
heatman101]
Aug 16, 2011 | Keurig Elite B40 Coffee Maker
Blue light keeps blinking and its full of water-- just got it today and it won't brew
heatman101-=-
[p
Aug 10, 2011 | Keurig B30 Mini Coffee Maker
My Keurig says not ready, water won't stop coming out. when it reads brewing, it stops.
heatman101
Jul 23, 2011 | Keurig B100 Coffee Maker
Sounds like it draws water, but won't make a cup in the morning. I usually have to power cycle a couple of times and then it works fine rest of day.
heatman101
Jul 08, 2011 | Keurig Platinum B70 Coffee Maker
The display keeps flashing Not Ready. Water is full. I've unplugged the machine and plugged it back in. Why won't it get ready?
heatman101
May 29, 2011 | Keurig B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
108 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
