Question about Olympia Office Equipment & Supplies
Olympia 1300 shredder does not shred - Olympia Office Equipment & Supplies
JayBlair
  • 328 Answers
SOURCE: My shredder stop shredding. has paper caught in itposted
You must have a stripped gear. Should be a number in op manual. Take the top cover off and look for the broken gear. Call them an order gear.
Posted on Aug 31, 2007
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
JayBlair
  • 328 Answers
SOURCE: when on
Make sure there is no paper blocking the sensors. Otherwise you may have a bad sensor or switch.
Posted on Jun 05, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
venexcsd
  • 1185 Answers
SOURCE: The shredder overheats. The most we can shred are
Have you put any shredder oil or a shredder oil sheet through the machine.
Shredders need oiling to keep the cutters free
Free cutters mean clean cuts and less friction
Posted on Jan 14, 2010
How do i increase the number of pages that the shredder will shred at one time?
you can only shred what it will take , trying to force more in will only break it faster .
Oct 16, 2015 | Shredder Office Equipment & Supplies
Takes the paper and then it backs up
This happens when the shredder detects an overload or potential jam condition. try making sure the cutters are lubricated with the correct machine oil and it will take paper in correctly. Experiment with feeding in different numbers of sheets to see what it is capable of. Avoid paperclips and stapes as they can damage the cutters and force the cutting blades to become misaligned which in turn puts additional stress on the motor and will mean that you will be able to successfully shred less paper than if the blades were OK and in good condition.
Oct 07, 2009 | Olympia Office Equipment & Supplies
Sensors not working correctly ... jamming
Try blowing some canned air down into the feed slot to clean the sensors.
Sep 23, 2009 | Olympia 1500.1C HS Shredder
Looking for replacement shredder bag clip for olympia model 3801A
I have been trying to find the clip you are asking for. I think what you should do is go to the Link and fill out the form so you can ask for the part. It is not on their website so you might need to explain what you need. Hope this helps.http://www.olympia-shredder.com/contact-us.html
Aug 24, 2009 | Olympia Office Equipment & Supplies
The shredder jammed (too much paper) then stopped and won't shred. It makes a noise, but when I insert paper, it won't shred. Is there a reset button? I picked paper out of the blades with a pair of...
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Mar 07, 2009 | OfficeMax 0M96431 Shredder
Olympia Shredder Jammed and not working
likely a spacer has broken, if you can see the underside of the cutting heads you will see a spacer or two hanging out, If this is the case the heads will have to be bebuilt or replaced.
Mar 06, 2009 | Olympia - 1452C CROSS CUT OFFICE SHREDDER
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Shredder Errors before Paper Touches Blades
When the paper shreds it pulls both the blades inward. Reverse spins them outward.
There must be something too large between the blades because it can be pushed up just not pulled down.
Has a staple or paperclip been inserted into the machine?
Try one of these two things:
When you're vacuuming the machine, hold the reverse button in and see if that helps.
Unplug it, take out all loose pieces like the bag liner, tape the door closed, get another individual to help you flip it upsidedown and GENTLY tap the machine to break free any obstructions.
Hopefully one of these solutions will work for you.
Jan 15, 2009 | Olympia 1500.1C HS Shredder
Olympia shredder 1280.6
On this model, make sure the hopper is all the way in. If it is, remove paper hopper and check to make sure the hopper is not broken. There is an electromagnetic switch in the front and the hopper has a magnet built in to it. run a stick magnet across the right underside and front to see if it extinguishes the light. If not, then the board is bad.
Jun 12, 2008 | Olympia 1280.6 Shredder
Aug 29, 2007 | Quartet gbc 6120S Shredder
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
