Question about Xerox 4110 4127 4112 4590 4595 Drum Cartridge 013R00646
Change drum cartridge in xerox 4112
How to replace drum cartridge
  • 208 Answers
SOURCE: No Magenta Color Printing, Xerox Docucolor 1632
Are the properties set correctly in the print driver.
You can turn certain colors up or down.
Does is copy magenta?
If so I would suspect the driver or the settings within the driver.
If it does not copy magenta, then I suspect a developer housing issue.
Printing only then suspect a driver issue.
Posted on Dec 10, 2007
SOURCE: reseting drum cartridge on xerox 3535
Yes I m drincopy from Kosovo i reseting oall drum for xerox
Valdrinjashari81@hotmail.com
Posted on Nov 30, 2008
  • 239 Answers
SOURCE: Xerox WCP 416 , it showed message replace drum cartridge
Make sure the copy cartridges are fully in place all the way in. Check to be sure you have a "New" cartridge and the plastic cover has been completely removed from the toner hole. Sometimes they break and the toner will not go into the drum, causing problems.
Sometimes the side door is not closed with both hands and causes the spring plugger not to fully go in correctly. The plunger breaks and will not open the cover on the copy cartridge. This causes other mechanical binds you cannot see.
Extra care is needed when closing this side door.
On this machine sometimes you need a Xerox service call to make repairs and replacements of broken parts and to ensure the copy cartridge is functioning well.
It might not be related to the toner sensor but due to updates the machine software can be made to make changes in the way the machine operates.
This can only be done with a Xerox laptop computer by the Xerox service representative.
This will fix scanner timing problems at startup due to software update changes.
I don't mean to give you another information, but will help you decide if you need to make other decisions in the future.
Good luck.
Posted on Oct 17, 2009
  • 628 Answers
SOURCE: Actualy my copier is xerox work centre 5020. My
Well, since the drum is a consumable, most of the copies is running life span counter. When the drum reached the life span, the message will pop out. Well, if the print out still ok, just ignore it.
Posted on Jun 28, 2010
SOURCE: Xerox 4112 fault 047-320
http://www.copytechnet.com/forums/xerox/68975-xerox-4110-fault-code-047-215-047-320-a.html
Posted on Feb 10, 2015
HOW TO RESET THE DRUM WARNING LIGHT ON MY XEROX XC1020
Reset the Drum Cartridge NOTE: This solution should only be used if you have already replaced your Drum Cartridge and the Drum Light is still on. If you have not replaced your Drum Cartridge, refer to Related Items at the bottom of this page.
If the Drum Cartridge has already been replaced and the Drum Cartridge Light still remains lit, the Drum Cartridge needs to be reset. To view an animated guide of the Drum Cartridge Reset procedure, refer to Related Items at the bottom of this page, or follow the steps below.
  1. Turn the power off.
  2. Press the Release Button to open the top half of the copier.
  3. Remove the Toner Cartridge by pressing the green Release Button and pulling the Toner Cartridge straight out.
  4. Set the Toner Cartridge off to the side, out of the way.
  5. CAUTION: Be careful not to touch the red shiny surface of the Drum.
  6. Remove the Drum Cartridge.
  7. Face the end of the Drum Cartridge that goes into the copiers. You will see a series of gears.
  8. Hold the Drum Cartridge so that the large black gear at the end of the Drum is to your left. There will be an off-white gear above and to the right of the black gear. Below that is a set of three chocolate-colored gears across the middle. Directly below the middle chocolate-colored gear is an ivory white gear. To the immediate right of the white gear is a small black gear. This small black gear will be the gear to focus on.
  9. At the top of this gear is a Retainer Clip holding it in place, then the gear itself. At the very bottom or base of this gear is a flat black Reset Flag. Some describe this Reset Flag as looking like a flag or the blade of a hockey stick. The Reset Flag may be partially obscured by the ivory white gear.
  10. With your fingernail or a pen, rotate the Reset Flag counter clockwise so that it is next to the third or far right chocolate gear.
  11. Reinstall the Drum Cartridge.
  12. Reinstall the Toner Cartridge.
  13. Close the top half of the copier.
  14. Turn the power on.
  15. The Drum Cartridge Light should now be gone and there should be a '1' in the LED Display. If the Drum Cartridge Light is still lit, repeat all above steps.
Dec 08, 2016 | Xerox Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Hi, I have a Workcenter XD102. It gives me a J2 error. I don't know how to fix it. Please help. Thank you very much, Charles
J2 error for Workcenter XD102 indicates a Drum Cartridge Problem sensed by the main PWB indicating that the Drum cartridge had reached its end of life. You may replace the Drum cartridge with a brand new Drum Cartridge. This should fix the problem.
If you believe that its not the Drum cartridge with or without replacing the Drum cartridge, you may try to open the printer, make a good clean and perform the below. 1. Check the PWB and Drum Cartridge Reset Circuit for any loose connection and short circuit. You may re-seat the cables and terminations and test. 2. If that didn't work you might need to get some voltage from the Drum Cartridge Reset Circuit as per below. 2a. If voltage is more than 0.5 VDC measured between PJ CN116-2 and GND then you need to replace the Drum Cartridge Reset Switch PL x.x. 2b. If voltage is less than 0.5 VDC measured between PJ CN116-2 and GND then actuate the Drum cartridge Reset Switch. Then check the voltage if its +5 VDC measured between PJ CN116-2 and GND. i. If not then replace the Drum Cartridge Reset Switch PL 5.. ii. Else it should be fine. iii. If not then replace the Main PWB, PL 7.1.
Jul 12, 2011 | Xerox WorkCentre XD102 Printer
My MF8180C is asking to replace the K cartridge, and I have bought a 301 toner cartridge but the printer has a drum cartridge instead. How do I replace the black toner into the drum cartridge or do I have...
the toner crg is located in front of copier, the drum is separated from toner and it removes if you open upper cover.
If the copier ask you for toner open front cover and replace toner.
You do not have to replace drum if the copier doesnt tell you to replace.
Jul 11, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
The toner tray will not pull out from the machine
Replacing the Toner Cartridge
The MFC can print up to 6,000 pages using a high yield toner cartridge. When
the toner cartridge is running low, the LCD shows TONER LOW. The MFC is
supplied with a standard toner cartridge that must be replaced after
approximately 3,000 pages. Actual page count will vary depending on your
average document type (i.e., standard letter, detailed graphics).
Discard the used toner cartridge according to local regulations. If you are not
sure of them, your local Sanitation Department. Be sure to seal the toner
cartridge tightly so toner powder does not spill out of the cartridge. When
discarding used toner cartridges, keep them separate from domestic garbage.
We recommend that you clean the MFC when you replace the toner cartridge.
1 Open the front cover and pull out the drum unit.
Place the drum unit on a drop cloth or large piece of disposable paper to avoid
spilling and scattering the toner.
2 Hold down the lock lever on the right and pull the toner cartridge out of the drum
unit assembly.
Caution
Handle the toner cartridge carefully. If toner scatters on your hands or clothes,
immediately wipe it off or wash it with cold water.
3 Unpack the new toner cartridge. Place the used toner cartridge into the
aluminum bag and discard it according to local regulations.
 Wait to unpack the toner cartridge until immediately before you install it in the
MFC. If a toner cartridge is left unpacked for a long period of time, the toner life
is shortened.
 You can use only a genuine Brother toner cartridge (TN-430 or TN-460), which
is specially formulated to ensure top print quality. Using another brand of toner
cartridge may void your MFC’s warranty. Warranty coverage does not apply to
problems caused by the use of 3rd party Toner, 3rd party Toner Cartridge or 3rd
party Drum unit.
4 Gently rock the toner cartidge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place.
7 Clean the primary corona
wire inside the drum unit by
gently sliding the blue tab
from right to left several
times. Return the blue tab to
the Home position ( )
before reinstalling the drum
unit assembly.
Reinstall the drum unit and close the
front cover.
Replacing the Drum Unit
The MFC uses a drum unit to create print images on paper. If the LCD shows
CHANGE DRUM SOON, the drum unit is near the end of its life and it is time
to purchase a new one.
Even if the LCD shows CHANGE DRUM SOON, you may be able to continue
printing without having to replace the drum unit for a while. However, if there
is a noticeable deterioration in the output print quality (even before CHANGE
DRUM SOON appears), then the drum unit should be replaced. You should
clean the MFC when you replace the drum unit. (See page 21-18.)
Caution
When removing the drum unit, handle it carefully because it contains toner. If
toner scatters and your hands or clothes get dirty, immediately wipe or wash
with cold water.
WARNING
Just after you have used the MFC, some
internal parts of the MFC are extremely
HOT! So please be careful.
The drum unit is a consumable item, and it is necessary to replace it periodically.
There are many factors that determine the actual drum life, such as temperature,
humidity, type of paper and how much toner you use for the number of pages per print
job. The estimated drum life is up to 20,000 pages. The actual number of pages your
drum will print may be significantly less than these estimates. Because we have no
control over the many factors that determine the actual drum life, we cannot
guarantee a minimum number of pages that will be printed by your drum.
Oct 02, 2009 | Brother MFC-9840CDW Laser Printer
Our xerox M118 showing an error"replace drum cartridge'can any one help me?Plizzz
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Dec 11, 2008 | Xerox WorkCentre M118 Black and White...
Replacing Drum Catridge
Hello, Here are the steps involved in replacing the drum assembly as copied from a users manual:
DRUM CARTRIDGE REPLACEMENT
The useful life of the drum cartridge is approximately 18,000 copies. When the internal counter reaches approximately 17,000 copies, the drum replacement required indicator will light up indicating that replacement of the drum cartridge will be needed soon. When the indicator begins to blink, the unit will stop operating until the cartridge is replaced. Replace the drum cartridge at this time.
1 Remove the TD cartridge (Toner Cartridge). Hold the drum cartridge handle and
gently pull the cartridge out. Dispose of the old drum cartridge in accordance with local regulations.
3 Remove the new drum cartridge from the protective bag and remove the protective cover from the cartridge. Then gently install the new drum cartridge.
When closing the covers, be sure to close the front cover securely and then close the side cover. If the covers are closed in the wrong order, the covers may be damaged. Do not remove the protective cover on the drum portion (black paper) of
a new drum cartridge before use. The cover protects the drum against external light.
Do not touch the surface of the drum (green portion) of the cartridge. Doing so may cause smudges on the copies.
4 Gently install the TD cartridge. Close the front cover and then the side cover by pressing the round projections near the side cover open button. The drum
replacement required indicator will go out and the start indicator will light up.
Aug 15, 2008 | Sharp AL-1217 Copier
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
Sharp 1655cs- replace the drum cartridge
There is a set of gears in the front of that drum cartridge with a flag on one of the gears, It has to be in the up position to swipe the drum replacement sensor. Most likely the flag had dropped in shipping.
You can take the green front off the drum and try and get that flag up and to the right. Or take the drum cartridge for a return and a new cartridge.
If that flag has dropped in shipping, it will not reset the drum count.
Apr 04, 2008 | Sharp AL-1655CS Copier
Xerox 4110 4127 4112 4590 4595 Drum Cartridge 013R00646 Logo
179 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
