Question about Samsung ML Office Equipment & Supplies
White stripe down middle of printed page - ML Samsung Office Equipment & Supplies
Inky
  • 691 Answers
SOURCE: Blank stripes on page left to right
If the blank stripes go up and down the page (vertical) then it sounds like the laser lens has simply got toner on it. remove the toner and photo conductor units. Look for the glass panel that covers the laser lens and simply wipe it off with a cloth. Some machines incorporate a lens wiping pad that can clean the lens without taking out the parts. I can not remember if the 1710 does or not.
Posted on Sep 16, 2007
  • 4 Answers
SOURCE: Epson AcuLaser C1100 - rainbow stripe
could be the photoconductor. see this post below, also try cleaning the print head
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Posted on Mar 06, 2008
SOURCE: Printer prints dark middle stripe on every page?
remove the cartidge and replace with a new one,
clean the rubber roller and check all drivers are installed correctly or that you have the most uptodate versions.
if this doesnt help solve it, you could invest in a printer repair kit specified for your printer usually found in p.c shops..
if all else fails call up the company.
Posted on Oct 30, 2008
  • 990 Answers
SOURCE: Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Posted on Dec 13, 2008
  • 6 Answers
SOURCE: I get this blue stripe down the right side of the page
Open the doors to locate and wipe off the green shiny roller really well. Spin it and wipe it off all the way, especially on that right side. Pull out the cyan toner and wipe it around where the toner comes out. Check other rollers for blue marks and wipes those off as well. Lit free cloths work best but I just use a damp paper towel and then a dry one.
Posted on Apr 27, 2009
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
Faded Stripe in the middle of the page
You need to clean the drum When I was working for the City There was the same problem with the Laser printers. Check the Manuel and see if there is a page on cleaning the print drum on your machine. Also you may try Talking the cartage out cleaning there as well It seems you are picking this up form somewhere after the print My Guess would be the print drum? You may also have to replace the drum as well. I am guessing that this is a laser printer? if not then there are other solutions.
Jun 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
White stripe down the middle of page when printing on HP 4240n printer.
Check to see if there is a peice of paper stuck in it. Then maybe get a can of air and try to clean it out. It could be dust built up on the print head. Paper gets dust in it when it is cut and will build up in printers.
Dec 01, 2009 | HP Office Equipment & Supplies
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
14 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
