Question about Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb
VACUUM WORKS NORMALLY BUT NO SUCTION IN THE WAND
2 Suggested Answers
  • 4 Answers
SOURCE: electrolux oxygen vacuum
WARNING WARNING Danger danger Will Robinson! The power head "wand" and the hose from the body of the vacuum have shorts in them. While my wife was using this machine.. she started smelling plastic.. seeing whitish smoke and then sparks... The pin connector arc'd through the plastic... Some research on Google found that this has been a large problem for Electrolux, when i tried to call the factory.. robots.... no solution. Then I contacted a distributor and they informed me that it was not really that big of a problem. Only later to say, that they had replaced ALOT of them. My unit was past its warranty period so I just hardwired it. (now the unit is only two pieces, body and hose w/wand.)
Posted on Nov 07, 2009
Dyson no suction in upholstery wand
Hi there, it's Jack at Dyson.
Like most Dyson upright vacuums, DC18 is engineered to divert suction to the hose and wand automatically when it's standing in the upright position. If your DC18 doesn't seem to have suction from the wand when standing upright, you may have a blockage in the hose or wand. Please follow the steps shown in our online Support guide to check for this: http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/no/remove-the-wand-from-hose
It's also a good idea to give the filter a wash - in normal use, this should be done at least once every 3 months as shown in the video below. Use cold water without detergent, and allow at least 24 horus for the filter to dry completely before replacing it.
I'm confident following these steps will resolve the issue. However if you'd like any further guidance from our experts after you've given this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 27, 2014 | Dyson DC18 all floors Bagless Upright...
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction when using wand on electrolux precision upright
There is a ball valve between the wand hose and the base hose. It can get stuck in the "base" mode, which won't then redirect suction to the wand hose. There is a spring under the cup that the open end of the hose rests in. When you release the wand from the holster with the one-touch quick release, that spring pushes the cup up and turns the ball valve to the wand setting.
  1. Unplug the vacuum.
  2. Using the one-touch quick release, remove the wand from the holster.
  3. Verify that the wand "cup" is indeed in the higher position. Do this by pushing on the bottom of the cup with your finger. It should easily depress.
  4. Remove the wand hose from the main unit using the quick disconnect feature. Put your fingers into the hole and feel to the right. You will feel the closed valve, verifying that it is stuck in "base" mode.
  5. Using a screw driver, insert the tip at the TOP of this valve and gently pry it downward. This shouldn't take much force.
  6. Reassemble the hose wand using the quick connect feature and reholster the wand.
  7. Plug in the unit and verify that the base unit has suction.
  8. Remove the wand from the holster and verify IT has suction.
Jul 27, 2013 | Electrolux EL8807A Precision BrushRoll...
Model DC40, the wand doesn't have any suction when I want to use on stairs, etc.
If your DC40 doesn't seem to have suction through the wand but picks up as normal on flooring, it's likely there's a blockage in the wand or hose. To locate and remove any obstructions, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc40/dc40-multi-floor/my-machine-is-not-working/machine-not-sucking-up-well/check-the-wand-and-hosedc40
It's also worth giving both filters a wash as shown in the video below - in normal use this should be done at least once a month. Use cold water without detergent and at least 24 hours for the filters to dry completely before replacing them.
I hope this helps, but if you'd like any further assistance please call our freephone Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC18 all floors Bagless Upright...
It wont pick up using the wand
There might be a few things you can try.
First, does the vacuum have a dial or control to turn the suction to the wand? If so, make sure you've set or turned this so that the wand suction is activated.
Second, most wands have a suction control vent. If this has been uncovered, the suction will not work efficiently. Look near the area where the wand connects to the vacuum and see if you can locate the suction control vent. There should be a plastic partial ring that can be moved to cover or uncover the hole.
I hope this helps. If so, please come back and rate my solution!
Jun 06, 2011 | Bissell Vacuums
I have little no no suction in my DC14 wand
must be a clog in wand?
Check to see if there's suction during normal vacuuming.
if so, there's a clog for sure in wand.
Sep 27, 2010 | Vacuums
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
Vacuums normally but no suction through the wand
Keep cleaning ... there is a clog somewhere.
Thanks for your intrest in FixYa.com
Feb 19, 2010 | Fantom Vacums XT450K Upright Vacuum
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The suction works in the wand, but not in the main vacuum
Sounds like you got wraped up in your work..
You need to take the bottom plate off and expose the brush. Once you in side you can unwind the mess. You should change the belt at the same time. Good luck. DFD
May 03, 2009 | Vacuums
Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
