Question about Nordic Track NordicTrack T7.0 Treadmill
Nordic Track T7.0: treadmill suddenly stopped in middle of workout. No power, no display. I tried unplugging for five minutes, plugging back in, still nothing. I did check the outlet of course, so there's power.Any suggestions?
SOURCE: Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
fishdoctorfi
  • 178 Answers
SOURCE: bad burning smell and turn off when i'm walking on it
Sounds like the BELT tensioner........
Posted on Mar 11, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
SOURCE: nordic track c2000 belt slips
I would try to tighten the rear roller a little and see if that helps.
1 start the treadmill and operate it at 1.5 mph then hild onto the handle bar and plant your foot against the belt at the front. If it slips tighten the roller 1/4 turn on each side. Then try the slip test again and repeat the process, do not tighten it too tight that will cause the belt to fold in teh center and be ruined. You May quite possible need a new belt. Take the belt lose and look at the underside and see if it;s glazed (shinny) or has pieces missing under the center of the belt, if so replace the belt and also clean the rollers front and rear, also flip the deck over it shoudl have a wax coating on the other side if that hasn;'t already been done.
Posted on Oct 23, 2011
SOURCE: Just purchased a new Nordic
nordic tractx7i
Posted on Dec 08, 2011
Run then stop after five minute
Check the reset/off circuit breaker. If the circuit breaker has tripped, wait for five minutes and then press the switch to the reset button.
You want the switch to be on reset, make sure that the power cord is plugged in. If the power cord is plugged in, unplug it, wait for five minutes, and then plug it back in.
Remove the key from the console, reinsert the key into the console.
These are just a few basic steps and if it does not solve the problem please do not hesitate to get in touch with our Technical Support Team by chat at www.sportsmith.net or by phone at 888-713-2880 we would be happy to help you further solve the issue. Hope this helps and we look forward to hearing from you :)
Aug 11, 2015 | Nordic Track Exercise & Fitness
I have a nordictrack cx938 elliptical that will not pass te five second mark on any exercise. Whether it be manual, or a preset workout once that five seconds hits it stops the workout. How do I reset? Or...
Dear Sir:
Adjust the reed switch. see the attached diagram.
4_23_2012_10_23_17_am.gifproceed according with your instruction manual, if you do not have go for free download: www. fitness.manualsonline. com or www. iconservice. com
sincerely. God bless you
Apr 21, 2012 | Nordic Track Exercise & Fitness
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    Just purchased a new Nordic Track T7.3 treadmill. Set it up and completed one perfomance workout plus 3/4 of a weight loss workout when disaster struck. The mill was placed on pause and when the start...
    Just had mine delivered on February 11th. Ran on it once and the screen went to complete contrast darkness. You could still see the display but you could see it better at an angle than you could looking right at it.
    Got on it today and the screen was completely blank just like you (after 6 uses). Sears came and the guy said the screens on these treadmills were junk.
    Apparently Sears will be replacing our treadmill at some point!
    Mike
    Jan 10, 2011 | Nordic Track NordicTrack T7 si Treadmill
    Nordic track commercial 1300 manual
    It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
    Jun 12, 2010 | Nordic Track Exercise & Fitness
    What do the distance numbers represent on the nordic track elite 1300
    If no distance goal was set, this display will show the distance that you have pedaled, in total revolutions. If a distance goal was set, the display will show the distance still to be pedaled during your workout.
    May 09, 2010 | Nordic Track NordicTrack Elite zi...
    My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
    my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
    Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
    Nordic Track NordicTrack T7.0 Treadmill Logo
    80 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
     Atlanta Fitness
    Atlanta Fitness
    Level 1 Expert
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
