Question about Refrigerators
LG GR349SQF multi air flow fridge/freezer
My above make fridge/freezer makes a buzzing sound, and although it doesn't bother me during the day at night it keeps me awake. Please can you suggest what it is and i can do. Many thanks
22yooper
  • 828 Answers
SOURCE: Electrical unit attached to compressor
Overload thermal protector is tripping out. When a mechanical refrigerator is unplugged it should remain unplugged for 5-10 minutes to allow the refrigerant pressure to equalize. If you unplug it and then plug it right back in the overload will open on and off until the pressure in the system balance to the point where the compressor will start.
This protector is a two way protector. It opens on Over current and or over temperature. If a condenser is plugged with dust , hair or what ever the fan which circulates the air for cooling the system will not move enough air to keep the compressor with-in operating temperature range. The thermal protector will open.
Posted on May 04, 2008
  • 1462 Answers
SOURCE: Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Posted on Jun 25, 2008
stradeteox
  • 88 Answers
SOURCE: freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Posted on Jan 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GC2224gek admiral freezer keeps defrosting
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Mar 28, 2009
Testimonial: "Thank you for your response. It was the circuit board that was faulty just over a year old. It was replaced just before I saw your email. "
  • 3600 Answers
SOURCE: i have a lg fridge/freezer and water flows from
You have a blocked drain hole at the bottom of the fridge put very warm water in the the drawers and remove once they un thaw then remove them and clean the drain hole in the bottom. If you need more help just post here and I will give you more informaion, also if it's got a lot of water you will have to remove the drip pan and drain it out
Posted on Aug 26, 2009
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
Defrost Timer
Probably a control Board problem. Without model #, I can't say for sure, but your fridge probably has a defrost board and not a timer.
Sep 05, 2017 | LG LRFC22750ST French Door 22.4 Cu. Ft....
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
Freezer working fine but fridge isn't
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG will not defrost motor making a noise like ice hitting it
I had this issue as well, techs replaced the control board and problem solved. Mine was done under warranty during the first year, hope yours isn't too expensive.
Dec 29, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
Dacor refridgerator model # ef488dcbss
Air flow from freezer to fridge box may be obstructed, ck for free flow there, no big steaks in the way of air to lower unit, or may be set too cold. Thats all i got for now, try it.
May 14, 2017 | Refrigerators
Freezer working fine, but Refrigerator no longer cooling
Sounds like there's an airflow problem to the top section. Things that cause no cold air to the top fridge section are... frozen up coils completely blocking most of air flow (defrost cycle not working), evap fan not working to blow air up to fridge, air control dampers in fridge closed or not working properly, or frozen air ducts supply/return. Pull the whole drawer out the bottom and take the rear inside back off to expose the coils. If they are frozen solid the defrost t-stat or defrost timer could be bad (heat element not usually bad). If there is a nice white frost all over evenly then that's OK. Check that the fan is running when the compressor is running to blow the air up and that there are no blocked air ducts, etc. If all that is good, check if you can feel good air flow from the upper vents with the lower door closed (that shows there is no blockage and the fan is running).
Jan 06, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
