Question about Bella Cucina 13330 Rocket Blender
Rocket blender stopped working when you place the jar down to blend it doe3sn't work
4 Suggested Answers
SOURCE: I am unable to get the blending cup out of my
I am having the same problem, someone please answer this
Posted on Nov 14, 2010
Hi! I just had the same problem and actually called the service number that came with the rocket blender. The lady on the phone said that the plastic cup must have expanded (from heat), and to stick it in the refrigerator for 24 hours until the plastic shrinks back down to normal. After the 24 hours the cup should be able to come off. Kind of makes sense, but I hope it works!
Posted on Feb 06, 2013
This has happened to me twice in two months. Both times it was my fault because I left it running for too long and the motor got too hot. Just leave it to cool off for 10-15 mins and you should be able to get the cup out. Putting in the fridge for 24 hrs seems EXTREME. Just have to let the motor cool down. I thought it had to be running to remove also, but this last time, I was able to unscrew it without it running. Don't let it run for more than 2 mins at a time and it probably won't happen.
Posted on Jun 02, 2013
Hi, Oh no!!!!!!, my blade has seized up and left little black bits of the gasket right under the blade in the jar. Can I get this gasket? We bought this absolute AWESOME Blender at the Home Show here in...
The bearing and seal are not replaceable. The bearing is sonically welded into thte base of the jar. The K-Tec is made by Blend-Tec, and any of the Blend-Tec jars will work as a direct replacement.
Sep 11, 2011 | K-Tec Champ HP3 Work Top Blender
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
Blendtec replacement jar
You can also go to http://veggiesensations.com to buy blendtec total blender parts. Hope this helps!
Jun 30, 2010 | Blendtec Extra Carafe / Jar for the Total...
I am unable to get the blending cup out of my Bella Cucina Rocket blender. I recently purchased this have and only used this a few times including once just before the ''cup'' stuck. It appears to have...
May 11, 2010 | Bella Cucina 13330 Rocket Blender
Replacement jar for a GE Insta Blend 14
Many blenders will work with a standard canning jar (pint or quart) I'm not sure if that will work for you, but it's a definite cheap fix.
Nov 20, 2009 | Back to Basics Blender Solution 5500...
My jugs are leaking too at the bottom. If anybody finds the replacement jugs somewhere please let me know. I have a double smoothie maker model 5787. Thanks! email me at javstarz@hotmail.com
My blender would do that if I didn't screw the jar on firmly enough. Sometimes the action of the blades will even loosen the bottom from the jar during blending, so I always hold the jar handle while the blending is going on. That way if it starts to undo, I can twist it back tight. Before I learned that trick I had smoothies leaking out the bottom - what a mess! Also make sure you put the gasket/seal on in the right order. If it's in the wrong place it won't seal correctly.
Sep 06, 2009 | Blenders
Krups blender blade stops
well it looks to me there is some thing not tight enough connection to ur blade.....as u say it works when empty but when u put soemting in its stops....this means ur blade is not tight on the shaft to the motor......or u may have done something wrong when u had the blender open........recheck ur work and make sure its tight,,,,,
if so u will have ur ice cold drink....cheers i hope so for ur shake
Jul 03, 2009 | Blenders
Blendtec blender jug split
I wouldn't fix the jar, just buy a new one. A crack, though rare, could possibly harbor bacteria. You could try using heat and melting it, but it wouldn't work as well. Your jar may still be under warranty, call Blendtec at 801-222-0888
Feb 24, 2009 | Blendtec Extra Carafe / Jar for the Total...
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Bella Cucina 13330 Rocket Blender Logo
207 people viewed this question
Top Bella Blenders Experts
eyecam
Are you a Bella Blender Expert? Answer questions, earn points and help others
