Question about Porter Cable 9118 #126 Porta Plane Door Planer
When i pull on the door handle from inside door will not open
2001 focus LR latch wont let door open. no child locks .outside handle limp inside handle sound like latch is being pulled how can i get the door open?
It would seem there is nothing else to do other than remove the door panel with the door closed. Removing the seat is likely to be necessary.
Not always possible to remove the door card without damage.
Welcome to my world...
Oct 06, 2015 | 2001 Ford Focus
What part do I need? It opens from the inside. The handle is not snapped.
Are you saying the inside door handle isnt snapped,but the door wont open by pulling on the inside door handle or is it the outside door handle thats not working??Both the inside and outside door handle has a spring and other components on the backside of the handle which cant really be seen unless you remove the whole door handle assembly.One of these components are most likely broken or the rod that attaches between each handle and the locking mechanism(part that locks into the door striker to keep the door closed and releases it too)might have come loose from the back of the handle.The outside handle is usually mounted to the door by pop rivets or bolts/nuts.The inside handle is usually mounted with screws,but it really depends on what kind of car youre driving.Youll probably have to remove the handle to inspect it for damage.Open the door and watch the locking mechanism for movement while youre pulling on the door handle.If it doesnt move when you pull on the handle,the handle is definitely broke or the rod has come loose from the back of the handle.
Mar 09, 2015 | Cars & Trucks
Driver side door
Hi Paul, I'm glad to help! Most problems with door handles that won't open the door is broken parts inside the door. Pull the door panel off and move the handle while watching inside the door to see what is broken. Once you've found the broken part, simply replace it. Hope this helps and have an awesome day Paul.
Feb 10, 2014 | 2004 Hyundai Santa Fe
Door handle broke
can you open from the inside, its the only way you going to get to sort this, failing that you may need to get a new door card and rip the one off the door at the top corner near to the lock latch and split the plastic and pull the door pin inside to open then take the door card off. sometimes you can do it with out braking the door card but would not say it will not brake. inside there is a plastic clip that the handle go's on then another bar to the lock. this is designed to snap if some one trys to open the door with force.failing that the handle part can snap where the bar fits to it. that you would need to change the handle.
Dec 06, 2013 | Land Rover Cars & Trucks
Why won't my driver's door open from the inside on my 2007 Ford Fusion?
Pull on the outside handle up once, then reach inside through the open window and unlock the door, try this and it may correct it self
Mar 04, 2013 | Cars & Trucks
Cant get the door open because the door handle is broke inside and out
You should be able to with a pair of pliers perhaps open door from inside -- otherwise you'll need to gain access from the inside panel.
Once the panel is off you should be able to pull the lever to open the door .......I hope this helps you.
Nov 06, 2009 | Cadillac Eldorado Cars & Trucks
Unable to open driver side door with inside latch on my 1997 chevy suburban. How to take off inside panel to see mechanism? Outside handle open the door okay.
take the bezel off around th door handle. take the screw out of the armrest. pull out the window switches and pull out on the door handle and pull up .disconnect the last two plugs then you can see the whole door handle
Jun 04, 2009 | 1997 Chevrolet Suburban
Driver side door won't open from the inside.
remove the inside door panel reach inside and, reattach the clip to the inside door lever rod
May 22, 2009 | HP Compaq Presario V5204nr Notebook
Drivers side door, not opening
VERY common issue.. the handle being replaced is ok.. but the actual metal rod that connects it to the latch needs bent a little to make it more responsive, what happens is over time this rod (which is bent slightly) will straighten, and the operator pulls harder on the handle which eventually brakes.. then replacing the handle will solve it for a while, until the trend repeats itself... VERY common, I have fixed hundreds in the shop so far...
Jul 10, 2008 | 1999 GMC Suburban
Porter Cable 9118 #126 Porta Plane Door Planer Logo
32 people viewed this question
Top Porter Cable Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Porter Cable Craft and Hobby Expert? Answer questions, earn points and help others
