Question about Garden
How do you tilt the cab over on a 6920s they is a oil pipe leaking under cab I cannot get to see which one it is.Y
A small amount of oil is dripping down the left hand side between frame and gearbox looking up from underneath you can see some oil on pipes.when you start tractor after standing over night you can here air in hydraulic pump for a few seconds then it's fine all day.
HVACRH20
  • 237 Answers
SOURCE: Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Posted on Nov 10, 2006
onyeredson
  • 404 Answers
SOURCE: Oil leak
Hello Pierre,
A little more detail may help me on this one, however this sounds like possibly your power steering pipe? both these use auto trans fluid it is reddy brown in colour and viscosity (Thickness) watery.
If this is the pipe, check the fluid reservoir it should have either a Yellow top with power steering or a steering wheel diagram on it.
If full then please give me more information as to location on engine where pipe comes from and goes too as nowadays engine oil is usually internally dispersed. Only oil cooler pipes possibly? will go to a finned type radiator usually near the front grille of the vehicle.
I hope this points you in the right direction as I'm thinking of giving this help up as very hard to remain on top slot when loads of questions responded to and no replies.
Good Luck,
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Posted on Jan 18, 2009
  • 7 Answers
SOURCE: 91 kx 250 blows smoke and drips alot of unburnt oil out the pipe
Does it have a stock pipe,carb,any modifications! If its stock,I would put a new ring and piston in it,it seems like your getting a lot of blowby,also make sure your air filter is clean. It would help if you used an iridium spark plug.
Posted on Jan 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
SOURCE: John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Posted on May 01, 2009
2004 chevy cav just had cracked radiator replaced with new one.. now small leak in front and tail pipe dripping water.
No, you should not worry. Tail pipe dripping isn't related to your radiator. It's common especially if your vehicle sits alot.
Small oil leak. You need to find the source of it. Use some good engine degreaser and clean it up. You should then be able to find where it's coming from as you fire it up and check around. I understand sometimes that's hard because things are packed in. How fast are you losing oil? Check the level on your dipstick.
Mar 03, 2016 | Cars & Trucks
Gas/oil dripping out of small weep type hole on the bottom of left outer exhaust pipe,and left cylinder not very hot thanks Help
Hi Lucien, sounds like you have a faulty spark plug, for more information about your question please visit the website below. Good luck and have a nice day.
1975 Suzuki Motorcycle Service Repair Workshop Manuals
Mar 18, 2013 | 1975 Suzuki GT 380
Lots of oil under my f150 crew cab not at head gaskets
pcv valves allow oil fumes to be burnt through the motor so the smoke would unlikely to coming out from under the hood.. To get you problem there has to be raw oil moving onto a hot surface such as an exhaust pipe. Check all obvious oil leak points such as front crank shaft seal behind harmonic balancer. check transmission oil cooler lines if fitted. check rocker cover gaskets as they can leak small amounts of oil directly onto the exhaust manifold mostly from the rear of the head. check for oil leaks at the rear main seal at the mounting cover. finally if the pcv valve is faulty then excess ive crancase pressure would have pushed the sump gasket9 or both front and rear seals) out of place and the oil again would be getting to the exhaust pipe.You say you have just had an oil change done check to see that the sump is not over full
Jan 06, 2013 | Cars & Trucks
Rubber hose for sharan tdi tear. could it be the cause of oil leakeage on the bonnet. apporox 3" hose
Hi
it sounds like an oil cooler pipe or an oil breather most likely the oil breather for the turbo, this is quite common that oil will build up in here and does leak due to the pressure from the turbo, remove the pipe as it should not have loads of oil in it basically just oil vapour that builds up over time then leaks out. cklean it all out everywhere you can see that has oil and see if the problem persits, also the car has a plastic pan / cover under the engine to stop any damage to the bottom of the engine when you go over things, however this is also like a pan to collect oil so it tends to gather in there in small amounts then drips out when the car is moved. the best advice I could give is have the engine professionally steam cleaned with engine degreaser and hot steam.
Once clean any leaks would be more apparent and this ofetn helps diagnose the fault quicker.
Regards
Dan
Jan 05, 2011 | 1998 Volkswagen Passat
The oil light is on. I check the oil stick and its has the recommended amount. When you step on the gas, the light turns off. I noticed it smells burned oil; must be from an oil leak that probably drips...
The dash light indicates oil pressure. When idleing the pressure drops too low and and light comes on. As it revs up, pressure increases.. light goes off.
You should go here and read about low pressure. Too much to copy and paste here.
http://www.buzzle.com/articles/low-oil-pressure-at-idle.html
The small leak onto the exhaust maybe more than just a nuisance, it is a fire hazard. Potential to catch fire. Clean off the COLD header and front pipe with a non flamable solvent cleaner. Also the engine case around the area. You may find the source of the leak.
Dec 31, 2010 | 2004 Dodge Stratus
Have a oil leak around engine
Have your valve seals checked, Mits is back on valve seals leaking and burning oil.
Jul 06, 2010 | 1997 Mitsubishi Galant
Grey/Whitish smoke (small amount) rising from rear of engine
Has to be a small oil leak above the exhaust header or pipe...Possibly the rear of the valve cover gasket...because the engine slopes to the rear, oil collects there, and drips off onto the exhaust. (I'm a 30 year retired British Leyland auto tech)
May 19, 2009 | 1995 Jaguar XJ6
Oil smell in cab
Get under there and look to see where oil is escaping. Oil, like everything else runs downward. Therefore it may be coming from the top of the engine. If you have a 4.0, the valve covers are plastic and tend to leak a bit... Generally you can gently (or you will break them off) tighten the v/c fasteners and eliminate most if not all of the seepage. If it continues, replace the gasket. There is only one seal between trans and engine, called a rear main seal. It is better left alone. It's a big job and best done by a shop.
Dec 30, 2008 | 1999 Jeep Grand Cherokee
Oil leaks onto the manifold pipe
I had the same problem check the oil sensor switch located above the manifold it is electronic with to wires I leaks when bad
Oct 20, 2008 | 1994 Toyota Camry
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
