Question about Frigidaire FTF530FS Front Load Washer
Vibration Issue I have been having some vibration issues. I replaced the shock absorbers and the vibration stopped for a few weeks, it's back. The washer is level, springs and legs are good...only thing left I know off is the bearings. Would they make any kid of noise when they are going out?
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: I am trying to replace a vibration shock absorber
yep,,, its striped its thread, get some moll grips on it and butcher it out? you will then need a new bolt,,,
darn silly idear them nylon bolts best thing for this bolt if melt it down and make stocking out of it?
Posted on Oct 23, 2009
  • 670 Answers
SOURCE: I have a Frigidaire model FWTR647GHS0 washing
I have this same exact washer, and the noise of the bearings could be heard from the basement to the second floor. The noise gets louder and louder as the bearing fail. The ball bearings are no longer round but misshapen as they rust and pit. The drum will have more play since the bearings are no longer true but they wobble as they turn. Unless you see that they are physically broken, the shocks and springs are probally ok. So replacing them won't solve your vibration or noise problem. The bearings need to be replaced.
Frigidaire wanted $250 + shipping for the rear drum with the bearings. My machine was 9 year old and the grease from the failed seal was dripping onto my clothes leaving brown stains when I decided to have it fixed. I did not want to spend $250 on parts to fix a 9 year old washer. But instead, after tearing the washer appart and seperating the wash drum into the two parts I just replaced the two bearings and seal. I pounded out the bearings from the rear tub and pressed in new ones. It took about 6 hours and less than $70 to fix. It's almost two years since I replaced the bearings and the machine is quiet enough that during a spin cycle you can have an normal conversation.
If you have some mechanical ability and a friend that willing to help you you can do it too. I got my bearings and seal from E.B. Atmus Co. The ones you need are 6307-2RS, 6306-2RS and seal number is 15939-CR. I learned how to do it by reading this blog. http://www.applianceguru.com/forum2/834.html
Hope this helps you.
Posted on Dec 07, 2010
LG FRONT LOADER 7KG DIRECT DRIVE WD11020D no longer detects imbalances,leading to flooding of the house after the vibration shook the inlet hose off. Can this be fixed? If so, how? Thanks kindly.
Having issues researching this model #, but front loaders fron LG have two springs and either 2 or 3 shock absorbers to dampen vibrations. Take top off and check that the springs are in place and not broken. If good then from the back or from underneath, check to make sure the shocks look good, connected, etc. if no obvious issues I would replace all the shocks because if springs are unbroken and in place, they are rarely an issue.. also, do a spin cycle without any clothes and see if unit spins without issues. It should. If it doesn't you may have a broken spyder that holds drum to hub. Bigger issue, hard to replace but possible. Good luck.
Jan 28, 2018 | LG Washing Machines
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
Front end vibration when going over bumps, almost like bad shocks. But I just put on new shocks 2 days ago. The truck doesn't bounce more than normal, but when going over small bumps at 5-25 mph. Going...
this may have something to do with worn suspension and steering joints. If the mechanic didn't tell you about the condition of the front end when he did the shock absorbers then be a little sus when you go back.
Aug 24, 2014 | Cars & Trucks
Washing machine vibration
I had same problem. It was actually wearing out the rubber gasket on front door. It ended up being the spider on back of drum. They corrode pretty good with the front loaders.
Mar 28, 2014 | LG WM1814CW Front Load Washer
When on spin getting a lot of vibration and noise
inspect the shock absorbers if noise is coming from the back during spin cycle
Dec 06, 2012 | Washing Machines
1999 Wrangler - Wobble/Vibration
this problem could be a worn or loose wheel bearing or a worn or broken shock or a worn tie rod inner or outer.
Nov 21, 2011 | 1999 Jeep Wrangler
Vibration from the back of sprinter , makes the whole vehicle bounce
This is most likely a faulty shock issue or bubble on a tire. Remove the tire and check it for a bulge on the tire indicating a weak spot and causing the vibration. If the tire checks out you will need to replace the shocks. Always replace them in pairs.
Nov 17, 2011 | Cars & Trucks
Vibrates when gas pedal pressed.
1. Check the ball-joint.
2. Check the Tye-rods.
3. Your shock absorbers/ struts.
4. Wheel balancing and alignment.
Good luck.
Dec 14, 2009 | 2000 Chevrolet Silverado 1500
Sony Play Station 3 wireless vibration issue.
Umm have u tried holding the ps button and then setting the vibration on from there?
Feb 25, 2009 | Sony Dual Shock 3 Controller for...
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
