Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Husqvarna lawn tractor change oil filter - Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
blueextc3221
  • 15935 Answers
SOURCE: What is the length of the primary mower belt for a
Many of the parts you can just drop the prefix and use the Sears /AYP #
So, look at the hood sticker or in your manual for the Husq#. 532 18 08-08 becomes 180808 which is a common Sears belt for their secondary belt on the newer 48.
OEP shows as a 5/8 X 89"
The primary for these 174368 (Engine to deck)OEP shows 5/8 X 90.
Best to get the oem if you can. Never tried aftermarket on these.
Also found THIS USEFUL INFORMATION.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 05, 2009
  • 27 Answers
SOURCE: My Husqvarna lawn tractor started smoking terrible
You mean Briggs and Stratton. Sounds potentially expensive. Call a local small engine repair shop. They'll tell you how much it will cost. A new engine might be $1k. Repairs a few hundred.
Posted on May 08, 2009
panilling9
  • 284 Answers
SOURCE: Where is the oil filter located on the Husqvarna
if its a 23 hp briggs and stratton it should be on the opposite side from the dipstick where you check the oil down low.
It may be black with a briggs and stratton label or it may be yellow with the same.
Posted on Jun 05, 2009
  • 376 Answers
SOURCE: knob on lawn tractor for blade engagement
Sounds like you need a new PTO switch.
Posted on Jun 15, 2009
stmc97
  • 41 Answers
SOURCE: Was mowing when it just stopped going forward. It
Under the mower below the seat of the rider, at the rear of the tractor, look up and you will find the transmission there. There is a belt that runs on the pulley under there, and this belt can slip off when it gets worn or stretched. Sort of a tough spot to get to but, that is most probably cause.
Let me know,
Chip
Posted on Apr 11, 2010
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
Jul 10, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
ENGINE OIL CHANGE QTY
Your owner's manual states: 51 Ounces W/Filter and 35 Ounces of Oil Without Filter. This info can be found under specifications.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_532430577.pdf
Mar 23, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
For some reason my husqvarna yth22v42 lawn tractor will run for a short period then suddenly stalls and dies out. at first i was thinking maybe the fuel filter needed changing so i changed it, while i was...
if it sputters then dies its your fuel system,if it dies completely its the electronic pickup or ignition module thats doing it,if you can heat the flywheel area carefully,it may do it for you after time and guide you to which problem it is
Mar 04, 2011 | Husqvarna YTH22V42 22HP Lawn Tractor 960...
How to reset oil change indicator on my husqvarna riding lawn mower
depends on how old the mower is, for the past 3-4 years, Husqvarna made it so that you have to replace the unit, unable to just reset it.
Jul 02, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Ch6 Oil code
Hello, W/D here.
What you are actually getting is Chg Oil (change oil). This is preprogrammed in, as a reminder for you to service the engine. It will go back to the hour meter mode after about 1 hour of additional runtime. If you have changed your oil and filter, there is nothing else to do. The oil and filter need to be changed regularly. If the oil breaks down in your engine, it will lose it's lubricating properties and the engine will seize up.
Best regards, --W/D--
Aug 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My mower dies when going down a hill. I figure a fuel problem is to blame but iv changed the line and filter. Im open for suggestions
does your mower have a low oil sendunit on it.
if so it might be bad it should around oil filter look around for one.just trying to help
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Where is the oil filter located on the Husqvarna Lawn Tractor, Model YTH2348
Jun 05, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
16 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
