Question about Archos Computers & Internet
When I turn on my RCA 7" tablet the screen goes white and has several different colored lines through it. They are thick and thin lines
When I turn on the tablet instead of turning on it gives me thin vertical lines and thick horizontal lines. You can not see anything that resembles words or symbols just lines.
antiochpc
  • 1314 Answers
SOURCE: Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
Posted on Dec 26, 2008
SOURCE: white vertical line on my hp compaq nc8000 monitor
notebook compaq nc800 , on the screen apeear vertikal white line ...what is this ..how to resolve this problem?
Posted on Jun 27, 2009
SOURCE: HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Posted on Dec 08, 2009
Kegtapper
  • 94 Answers
SOURCE: vertical lines on screen
Hold one side of the screen need top and flex slightly (Not twist, FLEX) if the full screen appears and lines are gone, you may need to have this fixed by a shop or replaced totally.
Posted on May 02, 2010
  • 165 Answers
SOURCE: it started as a horizontal bar with gray color and
Hi Friend, In this case I would recommend you to please try and connect any external monitor to the system to check if you have the same issue with the external as well.
If you see the same issue happening on the external one as well, i would recommend you to try updating the video drivers for the system
If the external one is fine, then I believe the LCD needs to be checked or repaired
Please let me know if it was of any help.
Thank you.
Posted on Jan 24, 2011
Testimonial: "thanks a lot..i tried everything you suggested already.. i think it needs to be replaced with a new one..thank you.."
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Jul 02, 2016 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
USED WRONG CHARGER ON RCA TABLET AND NOW SCREEN MALFUNCTIONING.HOW DO I FIX?
Try a factory reset of your tablet first. Here is a link to the procedure:
http://www.rcatablets.com/how-completely-reset-your-rca-android-42-tablet
Apr 29, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
The screen has lines on it, will not turn on or off, what do i do?
There should be a power button on the device, push and hold it until the device powers off. The length of time differs between devices, I would expect it to be between 10-15 seconds, if it doesn't react after a minute then there is a further problem.
If the there are still lines on the display when you have restarted it then you will need to contact dell for a repair.
Jan 11, 2015 | EEEKit 2-in-1 for Android Tablet, for Dell...
Hello......can anybody give any solution for this problem : my VGA Cable disconnect from the 15 Pin gents connector of Crt monitor of philips model no. 107E61 I want to fix it but I could not understand...
These connectors come with 15 pins and 9 pins. But be carefull, the nine pin connecter uses a tottaly different color code. Thats for an oldschool gamepoort or midi connector. But I think the vga connector has 3 rows of pins total of 15. But the nine pin connector has probably two rowes of pins. And thats no vga connector, but an connector for an serial port.
If it has three rowes (see Fig-2 below) but uses 9 pins then its an RGB instead of VGA.
Fig-1
Fig-2
Fig-3
Mar 19, 2017 | Cars & Trucks
White screen with colorful lines
If this is a touch screen it is broken. It is probably not cost effective to replace the screen.
Apr 13, 2014 | Nextbook Tablets & eReaders
My new 7 inch ematic has a white screen when turned and won't load the settings. It is model em63bl
I have a user manual that came with the tablet (though mine is a different model). Mine suggests holding down the power button for 6 seconds to reset the device. There is also a reset button; a hole on the back near the SD slot. I'm not certain what the difference is, but I would try both. I doubt you'll find a service manual for a tablet. I hope this is helpful to you.
Jan 16, 2014 | Computers & Internet
Dec 08, 2009 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
11 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
