Question about Pyle PLDN74BTI Car Video Player
Have picture but no sound except for in tuner
I hooked my head unit up as directed for a 09 jeep wrangler on the tuner it works great but I have no sound from the blue tooth or dvd
Getting condinsation on the inside of 09 jeep wrangler xl unlimited
Some condensation is normal, especially if you drive short trips. What to watch for is coolant lose and check the oil to see if it has turned milkly on you. this would indicate that you have a blown head gasket. if this is the case do not drive the vehicle anymore, as this will cause more damage to the engine.
Dec 27, 2010 | 2009 Jeep Wrangler
Vrv785bt- No sound except tuner
sounds like u have a premium sound system. what u need to do is take ur blue/white remotewire to ur blue power antennat that should activate ur factory amp.
Apr 16, 2009 | Clarion VRX785BT Car DVD Player
Coolant near the transmission
its the head gasket. to be safe, i would suggest changing both seals but, the head gasket will leak in this direction .
Feb 27, 2009 | 1988 Jeep Wrangler
Subwoofer doesn't play through ipod, only radio and cd's
Hook up the remote wire from the head unit (grey w/ orange stripe) to the power antenna wire (blue) on the wiring harness adapter.
Jan 15, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
Radio install dash kit for jeep wrangler
yes they make them and they are sold at walmart for about 10 bucks a thing
Jan 03, 2009 | 1990 Jeep Wrangler
Tuner problem?
This is an indication of a bad ground connection. Since you have replaced the cable and splitter, it suggests an internal grounding problem. If you can solder and can get to the tuner, resolder the ground points within the tuner and update this with the results.
Dan
Sep 30, 2008 | Panasonic CT-27E13 27" TV
Pyle PLDN74BTI Car Video Player Logo
13 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
