Question about Tritton X360 Warhead 7.1 Headset
To friends mic sounds far away
Would like to know how to fix
Philips shm1900 headset on Lenovo thinkpad t430 with windows 7
It sounds like you are still using the mic on the laptop. Because you are far away from it, it sounds like echo.
Make sure the phillips headset is selected in the Windows mixer.
Make sure you are plugged into the mic jack on the laptop.
Make sure the mic is not muted. This is a default setting.
Apr 02, 2014 | Philips SHM1900 Headset
My Skype mic is not working. The receiver can hear me but I cannot hear them. Please assist.
This problem maybe from his/her side, or it's also possible from you speaker settings, if you are sure that there's no mic problem from your friend, follow the instructions below; (this is to be done on your skype settings)
Sign in to your skype account > Options > click Audio Settings on the left pane > Move the Speaker slider towards the right hand side (High) > Click Test (the green play button), if you can hear the "test sound" save the settings and try calling your friend again.
(This is to be done on your friends skype settings) Let him/her log in to his/her account > Options > Audio Settings > Mic volume (slide the volume to the extreme right) > save and try again. You can also do the settings while you are on the call with him/her so that you can see/know the changes instantly. If there's no problem with the mic or speaker, this will definitely fix it.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | HP Pavilion dv6000z Notebook
The people I call say it sounds like I am in a well?
R U in a well?
The mic is too far away from your voice and is picking up surrounding "white noise" and causing your voice to sound distant and echoy (is that a word?)... move the bottom of the phone, where the mic is, closer to your lips and not under your chin.
LG makes good phones.
Sep 25, 2009 | LG AX245 Cellular Phone
My yamaha did not come with the optomizer mic
You can, and the results might be better than not optimizing, but they might be worse.
The optimizing process listens for resonant frequencies in the room (what pitch "rings" longer in your room) as well as damped frequencies (what pitch sounds "dead" in your room)
To do this, it needs a mic that's matched to the unit.
Different mics have different frequency response curves, so your friend's mic might think (for example) that 2500hz is really hot, but the yamaha mic would think it's normal.
Certainly won't hurt to try, but if you don't like the way things sound after optimizing, then just reset your yamaha to the default EQ.
Sep 16, 2009 | Yamaha YSP-800 System
Dual XDVDN8190 Hearing problems through Bluetooth
talk closer to radio the mic is a tiny hole on front right
Aug 30, 2009 | Dual Electronics XDVDN8190 GPS Receiver
Mic static noise comming and going
i know someone who can solve this a solution
Feb 24, 2009 | Logitech QuickCam Messenger Web Camera
What setting do i use to run my cordles mic in to audio 1
Without more clarification I am assuming that you have the onboard mic plugged in normally & I don't know where the RF mic is connected.
First thing is that we know that you get sound from the shotgun mic in ch. 1. If you do not plan on using the onboard shotgun, then the fix is easy! Since it has been confirmed that ch. 1 works, just disconnect your shotgun & plug in the RF receiver to that, check your levels, and shoot away.
If you are still wanting to use that shotgun along with the RF, then I suggest that you re-read pages 51 - 54 of the instruction manual. You can find where to jack in, how to set, and change audio levels on these pages. Good Luck!
Feb 10, 2009 | Canon XL1S Mini DV Digital Camcorder
External mic problem for acer aspire 5920
reboot the sound card trough the device manager.
Nov 11, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Mic problems online
If your mic is a bluetooth then it could be that your far away from your ps3 when your playing.
Aug 05, 2008 | Sony Resistance: Fall of Man
Have prob wit cb radio
I WOULD CHECK THE COAX CONNECTION @ THE ANT HAVE SOMEONE MOVE THE WIRE AT THE ANT CONNECTION WHILE YOU LISTEN INSIDE IF THERE A LOOSE GROUND YOU WILL HEAR IT ON THE RECEIVER SIDE.. ALSO CHECK YOUR MATCH WITH AN SWR METER.. DON'T TRUST THE ONE ON THE RADIO IF YOU HAVE ONE GOOD LUCK
May 04, 2008 | Radio Shack TRC-447 CB Radio
Tritton X360 Warhead 7.1 Headset Logo
11 people viewed this question
Top Tritton Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Tritton Radio Communication Expert? Answer questions, earn points and help others
