Question about AT&T Lands Phones
Phone doesn't ring - AT&T Lands Phones
Phone doesn't ring
Switch the ringer on but if you already did that you should plug it in go on that website you mensioned and go to help.
May 05, 2013 | Apple iPhone 4 Black Smartphone
Alcatel go phone won't ring
I am not familiar with this Alcatel phone at all. It is my husbands phone. Anyway, he came in and said that his phone is only vibrating and nor ringing. Can someone please walk me through the steps to fix. Thanks.
Mar 26, 2013 | Cell Phones
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
Nov 27, 2012 | NEC Dterm DTP-2DT-1 Phone
How do I undo the delayed ring on a toshiba dk2010sd phone?
just check your ring tone settings check whether u have selected vibrate then ring settings..if so change it to ring..try this....
Nov 22, 2011 | Lands Phones
My co-worker's voicemail doesn't pick-up until it rings 12 times. how do we change it?
From his phone, on the intercom, dial *71324 You'll hear a tone and that makes his phone ring 4 times (24 seconds) and forward.
Carl
Aug 24, 2011 | Panasonic KXDT343 Phone
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
I can't pick up a phone call
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
I hope this helps.
Mark
May 24, 2010 | Mitel 5212 IP Phone
When a call comes in the ringer doesn"t ring
you need to have the phone programmed to ring. ldtsnj.com can help
Jun 16, 2008 | NEC DTU 8D-2 Corded Phone
Lands Phones Logo
23 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
