Fuse # 20 or 21 gets power through ignition. This fuse controls PRNDL indicator, speedometer, tach, & will cause transmission to not shift gears correctly. Ours took off in 3rd gear when put in Overdrive & only ran in 3rd gear. If we tried to manually shift thru gears (auto trans), it had 1st, 3rd, reverse. No 2nd or over drive. Replaced ignition. Fixed problem. Root problem was Electric motor that engaged 4 wheel low side was bad. Every time we used 4 Low side it threw power surge through ignition & blew ignition out. Good Luck.
