Question about Umax Astra 2000P Flatbed Scanner
Showing error
When I try to scan  or try to preview  it showing  error 0000h
    Novelist:
    Scholar:
  • 167 Answers
Reinstall driver
Posted on Oct 27, 2007
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
Used to work fine, now after scanning a document, preview shows right 1/2 inch cut off. Tried everything...
you might confirued wrong paper setting on print preview of scan document or try to change the size of the paper to A4 or letter
Nov 12, 2013 | Lexmark International Lexmark 5200 series
Error 2200
The Downloaded software may not have the Lexmark Imaging Studio on the downloaded drivers....
In this case u have to scan and Preview the scanned images using Windows Photo Gallery.....
Click on File and Click on Import from scanner or Camera...........
Then again click on Import...........It will scan and preview the Applications to u....
Please try the above mentioned steps and let me know what happens?
Feb 22, 2013 | Lexmark P6250 All-In-One InkJet Photo...
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
Scanner not working
Do you mean to say that while previewing the light moves and you are able to seek the preview, but the light not moving while you give a scan command?
If this is true this is something unusual. May be you have some hardware problem.
S. Mohan Chennai
Mar 07, 2008 | HP ScanJet 2400 Flatbed Scanner
Error in Scanning
Sorry to ask u ,how old it is,this kind of problem is found due to following reasons
1)driver software:uninstall n reinstall driver
2)scanner is dusty:clean the scanner from inside
3)inner scanner cable(black cable) defective:replace cable
but before all try this
1)go to my computer,u can see icon of scanjet 2400
2)right clk,clk get pictures.....,new window will open,
3)click preview n wait n see does it shows the preview?
4)if it shows preview then reinstall hp director,or try above mentioned steps,definately the problem will be solved,
thnx
Jan 24, 2008 | HP ScanJet 2400 Flatbed Scanner
Scanning negatives on CanoScan 600F, I get an error message "Cannot write or read. 252.0.0"
The Canon support site is the place to go for that if your Manual does not tell you.
However remove the software and reload it - it may be as simple as that.
Dec 26, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Scanning Different Sized Sheets
There should be a preview option that scans more quickly than actually scanning the page. Then after the preview shows, you can select the area that you want to actually scan and then you hit the Scan button. If you are using the Canon software, this should work for ya.
Nov 07, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Error 00000h
How old the scanner
What operating System
Has it worked OK with this O/S
Oct 26, 2007 | Umax Astra 2000P Flatbed Scanner
Umax Astra 2000P Flatbed Scanner Logo
29 people viewed this question
Top Umax Office Equipment & Supplies Experts
Ricky Ostrom
Ricky Ostrom
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
