Question about Boston Acoustics BA735 Computer Speakers
Boston digitalba735 won't work on a dell xps 400
Xps 400 6.0 gb/s hard drive upgrade wont work
Did you initialize the drive in control panel, administrative tools, computer management, disk storage?
Mar 03, 2014 | Dell XPS 400 PC Desktop
Squealing Dell XPS 400
Check the power supply sounds defective
Aug 07, 2012 | Dell Dimension XPS 400 PC Desktop
What is the absolute best video card I could use in my Dell XPS 400, Pentium D3.0GHz Processor with 4GB of RAM?
Your limitations will be
1. Your power supply, as it's only a 375W you have to be aware of power consumption.
2. Your budget, This will decide what you can afford.
Also you need to see what the recommendations are for you applications you want to run. Keep in mind that with your system the CPU will be the limiting factor, there's no point spending lots and lots on a card that won't be able to operate to it's maximum potential.
Mar 07, 2012 | Dell XPS 400 Dual Core 2.8Ghz, 512MB,...
Led light is solid on my dell xps 400 and system wont start? any ideas?
Can you be more specific when you say the system won't start?
If the system does not turn on at all or turns on for a second and then shuts off it is very likely due to a power failure. If you have installed any new harware recently unplug it and try to start the system again. If problem persists it is likely faulty power supply which a fairly cheap fix.
Jan 06, 2011 | Dell XPS 400 PC Desktop
Where is the memory card slot on the Dell XPS 400?
What kind of memory card are you talking about?
If it's one of those cards from a camera, PDA, etc, it should be on the front of the computer, if you purchased that option.
The normal XPS 400 does not have a memory card reader.
Oct 25, 2010 | Dell XPS 400 PC Desktop
My Dell xps 400 will not boot up completely, then won't power off
It sounds like the machine is experiencing hardware problems. You will either need to call Dell or take it into a local computer repair place.
Nov 16, 2009 | Dell Dimension XPS PC Desktop
Need to install PCI card in Dell xps 400, but can't remove back to get to slots. No tools for 2 little black screws what to use?
You shouldnt need to unsrew anything on the xps 400.. Everything the case opening and the pci card screws should also be a latch!
Nov 15, 2009 | Dell XPS 400 PC Desktop
I'm looking for audio drivers for my dell xps 400. i just reinstalled windows xp media center. no sound card, just motherboard
here is an drivers for your dell xps400
http://www.user-guides.co.uk/download/audio/audiodrivers/audio-drivers-dell-xps-400.html
Sep 23, 2009 | Computers & Internet
Boston Acoustics BA735 Computer Speakers Logo
22 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
