Question about Miele Ovens
Miele oven buzzer not working - Miele Ovens
Oven with no power output
Check your house panel and reset the breaker for the stove.
Jan 21, 2014 | Miele Ovens
How do I set the clock on the Miele oven?
I don't believe this model has a clock feature - just cooking timer. I checked through the operation manual and did not find any indication of a clock function. The manual is available here:
http://www.mieleusa.com/manuals_pdf/Residential/Ovens/H350-2_us.pdf
Mar 15, 2011 | Miele Novotronic H350-2B Electric Single...
Miele Oven H387. Oven does not heat up. Everything else seems to work fine. All troubleshooting ideas in manual are exhausted. Thanks
If the fan is working o/k, then it is more than likely a faulty element, this is located at the rear of the oven compartment behind a removeable cover.
Sep 09, 2010 | Miele H387-1B Electric Single Oven
Volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Jan 12, 2010 | Candy Ovens
Replacement Door Hinges Miele Oven
hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
Jun 14, 2009 | Miele DG 4080 Stainless Steel Electric...
Older jenn air wall unit oven / turn knob
Yes, I just had same problem. The probe receptical is on the right inside wall of the oven. A little flapper door is secured by a single phillips screw. Remove this screw and the flapper door. Gently remove the receptical and its attached cable adapter. With your screw driver short the connector extension to the housing, just as the probe would. This should reset the meal temperature sensor. Try the bake and problem should be gone. If not permanently short this connection with a wire. You won't be able to use your probe, but the oven will work.
Feb 23, 2009 | Ovens
Miele Microwave Oven M636 EG
Use Miele UK
http://www.miele.co.uk
click Customer Support
then
click Operating Instructions
select File;
  • M616, M626, M636
free download PDF format
May 02, 2008 | Miele DG 4080 Stainless Steel Electric...
Ovens Logo
15 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
