Question about Jeep Chrysler Dodge Factory Radio / Cd P05091506ae
Need stock radio harness for p05091556ah - Jeep Chrysler Dodge Factory Radio / Cd P05091506ae
I have a 95 gmc sierra 2500 and im trying to put in my aftermarket rafio so i cut the stock harness out the square puece that goes in back of stock radio and now i cant figure out what wire is what i got...
I would suggest you spice the wires back to stock harness by male and female connections and tape over them with black tape then get a stereo install kit that includes a wiring harness ( cost about $20 maybe or less) for the year of truck you have... it will plug right to your stock harness ...never just cut stock stereo wires from stock plug it will be more of a headache than you think trust me I've installed all my own stereo system been there done that... good luck
Mar 31, 2015 | 1995 GMC Sierra
Trying to install a radio in my 97 nissan kingcab xe pickup but i cant find a diagram for the stock radio wiring harness anywhere, help me?
if the stock pigtail is cut, that sucks! you can always get an adapter harness, even from walmart! plug and play. just splice the new harness into the new radio harness. easy as all connections are color coded. if you talk to a service writer at nissan, you may be able to get a diagram from them.
Nov 15, 2013 | Cars & Trucks
I need please the electrical functions of each cloured wire form the back of the unit
If you are installing a radio, I recommend you get a wiring harness. All aftermarket radios use a standardized color scheme for the wires. If you purchase a wiring harness, you attache the radio to the harness, then plug the harness into the stock vehicle harness. You can find one a www.crutchfield.com
Aug 24, 2011 | Car Audio & Video
Would like to change the stock radio... how do I do it
THIS IS A COPY OF A POST I SUBMITTED TO SOMEONE WHO HAD A SIMULAR QUESTION REGARDING AN ALPINE BRAND RADIO ISTTALLATION. THE PROCESS IS THE SAME NO MATTER WHAT BRAND THE AFTERMARKET RADIO IS.
Go to the store and buy a mounting kit and wiring harness adapter that are for your car. There are alot to choose from and most are universal and come with instructions. You can get these at wal-mart or best buy. The mounting kit is meant to fill in the empty space left by the new aftermarket radio (your alpine). The alpine will have a metal sleeve around it. take this off and put it in the mounting bracket so it is flush. The sleeve will have little triangle shaped tabs on it. Bend these out so the sleeve cant fall out of the bracket or someone will be able to pull out your radio. Remove your stock radio by pulling off the trim around the radio. This is held on by clips, so be careful. There will be a couple of screws holding in the radio. Remove these and pull the radio out. Behind the radio there will be 1 or 2 wiring harnesses plugged into the radio. Unplug these. Then attach the wiring harness adapters you bought. These plug into the stock harness and have wires at the other end that are labeled. Wire the alpine wiring harness into the harness adapters that you plugged into the stock harness. If you want to you can unplug the harness from the alpine and wire it to the harness adapter before plugging it into the stock harness. The wiring diagram should be on the radio. If not the colors are pretty common.
RED = SWITCHED PWR LEAD (IGNITION)
ORANGE = ILLUMINATION
BLACK = GND
YELLOW = BATTERY LEAD
GREY = FNT SPKR RIGHT(+)
GREY/BLACK STRIPE = FNT SPKR RIGHT(-)
WHITE = FNT SPKR LEFT (+)
WHITE/BLACK STRIPE = FNT SPKR LEFT (-)
VIOLET = REAR SPKR RIGHT (+)
VIOLET/BLACK STRIPE = REAR SPKR RIGHT (-)
GREEN = REAR SPKR LEFT (+)
GREEN/BLACK STRIPE = REAR SPKR LEFT (-)
BLUE = PWR ANTENNA LEAD
BLUE/WHITE STRIPE = REMOTE TURN ON LEAD(FOR SUBWOOFER AMPLIFIER)
There may be RCA jack inputs in the back and these are for the subwoofer amp.
There will be a large black cable in the back and this is the antenna wire. Plug in the antenna wire from the back of the stock radio here. Yu may or may not need an adapter for this depending on the size difference between the wire and the hole it plugs into.
**Please note: if your car has a "premium" sound system that comes stock with an amplifier you will need to attach the power antenna lead from the alpine to the remote turn on lead on the harness adapter. If not when you turn on the radio/cd it will not turn on the stock amplifier and the speakers will not work.
I found this out with my 99 dodge avenger which has an Infinity stock radio. You can pop the trunk and look up at the back dash and see the small amplifier.
Once the radio is wired and the mounting bracket is installed, connect the harness adapter as well as the antenna wire. The new wiring harness adapter makes the wiring a little longer so you may have to stuff them back a little bit. Connect the harness from the alpine back into the back of the radio and slide the head unit into the metal sleeve until you hear a click. Before sucuring the mounting bracket and putting the trim back on it is a good idae to try the radio out so if there is something wrong you dont have to disassemble it again. When you buy the harness and bracket it will say on the packaging "nissan 84-94" or "Honda 83-99" or something similar. Look on the back for a complete list of compatable models
please vote and thank you!
Oct 17, 2010 | 1995 Oldsmobile Cutlass Supreme
Looking for instruction to operate an Alpine MDA-W905JB head unit in a Japanese car I just bought.
BLACK = GND
Once the radio is wired and the mounting bracket is installed, connect the harness adapter as well as the antenna wire. The new wiring harness adapter makes the wiring a little longer so you may have to stuff them back a little bit. Connect the harness from the alpine back into the back of the radio and slide the head unit into the metal sleeve until you hear a click. Before sucuring the mounting bracket and putting the trim back on it is a good idae to try the radio out so if there is something wrong you dont have to disassemble it again. When you buy the harness and bracket it will say on the packaging "nissan 84-94" or "Honda 83-99" or something similar. Look on the back for a complete list of compatable models.
Hope this was helpful. Please rate, and thanks!
Oct 17, 2010 | Car Audio & Video
Need wiring guide for replacing stock radio 1996 ford windstar with Dual Model XD 1222 radio have harness still need wiring assistance
I would get an adapter harness that will plug into your existing vehicle plug, and the wires are color coded to match up to most aftermarket stereos. You could check e-Bay, or a local automotive audio store for the adapter harness.
May 10, 2010 | 1996 Ford Windstar
I need a wire diagram for 96 a chevy lumina and a 95 cutless supreme oldsmobile for stock steroes
96 Chevy
Battery ORANGE (+) RADIO HARNESS Accesory YELLOW (+) RADIO HARNESS Ground BLACK/WHITE (-) RADIO HARNESS Illumination GRAY/BLACK (+) RADIO HARNESS Dimmer BROWN/WHITE (+) RADIO HARNESS Power Antenna PINK (+) RADIO HARNESS LF Speaker (+) TAN LF Speaker (-) GRAY RF Speaker (+) LIGHT GREEN RF Speaker (-) DARK GREEN LR Speaker (+) BROWN LR Speaker (-) YELLOW RR Speaker (+) DARK BLUE RR Speaker (-) LIGHT BLUE
Apr 04, 2010 | Car Audio & Video
I need to know which colour wire from the radio is for what, so i can fit a non standard stereo
My best advise is not to cut the stock wire harness plug. Go online or to your local best buy and buy a wiring harness that will plug into your stock plug and into the radio. then you don't need to know what any wires are. cutting the stock harness is opening a can of worms.
Dec 23, 2009 | Car Audio & Video
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Need wire color codes for 2000 cavalier stock radio
Accesory need to go to the ign switch cause radio does not provide a switch source.
Ground BLACK (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
Feb 25, 2009 | Car Audio & Video
Jeep Chrysler Dodge Factory Radio / Cd P05091506ae Logo
35 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
