Question about Alpine Air XL-15 Air Purifier
Ozone not working
No zone blowing
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
I have an Alpine ZL-3 and we can't smell the ozone any more. Our air doesn't smell fresh any more. My husband has been cleaning the ozone plate with warm water. Does this have anything to do...
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
May 25, 2011 | Alpine Air XL-15 Air Purifier
My xl-15 air purifier works but it does not blow out air with the purified smell. I think I see people calling it ozone.bthere used to be what looked to be an illuminated orange light behind the fan. It...
Easy. You need new plates in the machine. They cost about $15 a piece. Google 'ozone plates for XL-15' & sources will come up on where to buy them. Remember to clean the plates every 30-45 days w/ 50-50 solution of ammonia & water & a tooth brush on these plates. Dry thoroughly w/ hair dryer before putting back in machine.
Feb 15, 2011 | Alpine Air Purifiers
My xl15 runs but does not produce ozone. The little Rulien fan on the little ozone maker does not run. the regular fan works though.
You realize this is a really old machine!! The little fan is for ozone level detection, not production.
To see if the machine still will produce ozone
1) Set the switch to manual rather than auto and always run it on manual.
2) Remove the back of the machine and remove the 4" white plates. Check them for cracks, breaks in the mesh, loose mucilage, discoloration, burned spots, excessive grease or nicotine, or particulates such as dust, dog hair, or lint. Clean the plates using a solution of 1 part plain AMMONIA to 1 part warm water. Soak 5 minutes, brush with a soft brush, rinse well, and blow dry. DO NOT use any kind of cloth to dry the plate. Avoid putting fingers on the mesh.
3) If the plates are damaged in any way, call Vollara (new name for EcoQuest) and order replacements. 1-800-989-2299. Use #16618 as the dealer referral number if you are no longer in touch with the registered distributor who sold you the machine.
4) Insert the plates, making sure the metal contact fingers press on them firmly.
5) If none of the above works, most likely the power to those contact fingers is no longer strong enough to arc through the plates.
6) Call customer service, and they'll explain your options.
Feb 10, 2011 | Alpine Air XL-15 Air Purifier
I was considering Biozone for restrooms etc and I assumed,as your info.says that it would be odour free?Some I have seen are not odour free.Is it just a uv lamp system or is there some form of ozone...
the UV lamp does produce some ozone .. this one specifies .04 ppm .. thats not very much but might be detectable as a slight fresh air odor .. some other types use electrostatic filtering and some even have strong ozone generators .. ozone does kill bacteria, fungus and such and will freshen the air removing many odors but is not considered healthy in large or concentrated amounts or for prolonged periods .. the UV lamp will also kill bacteria and fungus without producing so much ozone.
Purifying Method: Photoplasma, UV, ions, and ozone.
Oct 09, 2010 | Biozone 500 Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
Green light is on, fan is blowing but we know longer smell the ozone from it; we have just changed the plate & cleaned it?
Apr 18, 2010 | Ecoquest Living Air Classic Air Purifier
It dont blow out air,,doe;tsclean air quite
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Sep 08, 2009 | Sharper Image Ionic Breeze 3.0 Air...
The ozone generator quit working. What is the problem and where can I get parts ?
You can pull off the rear filter, pull the ozone plates, defeat the safety interlock, turn the unit on, and place a screw driver (holding the plastic handle) one one of the ozone bars, and try to make an arc between the screwdriver and the other bar.
If you get an arc, the ozone plates are dirty. Clean well with a brush and sudsy ammonia. If no arc, either the hv transformer is bad, the main circuit board is bad, or the ozone control is bad.
There's one other thing you can check: The two wires that connect to the ozone bars can arc to the chassis sometimes. You can inspect the insulation on those wires to make sure it is intact.
May 12, 2009 | Eagle Advantage Alpine Air Purifiers Eagle...
Fresh-air purifier does not geenerate ozone
The fan is bad it should blow the fuse, I believe that the mother board has a problem, or the Display board may have gone bad.
Nov 04, 2007 | Ecoquest Fresh Air Air Purifier
Alpine Air XL-15 Air Purifier Logo
24 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
