Question about Jabra Black SOLEMATE Portable Bluetooth Speaker 1009710000002
Broken charging port on jabra solemate
Charging port broke and fell inside unit
SOURCE: CHARGING My Jabra bt160
i have the same problem
Posted on Feb 18, 2008
  • 4 Answers
SOURCE: Jabra bt250v Indicator light doesn't remain on...
i have just repaired my bt250 with this problem, i hadn't used it for around 2 years and when i put it on charge just got i flash of blue led. the fix was to "jumpstart it" the headset needs to se some sort of battery voltage to start the charging process, i stripped mine right down but that was just to fiddley. IF YOU DO THIS IT WILL BE ENTIRLEY AT YOUR OWN RISK AND I TAKE NO RESPONSIBILITY IF YOU TRASH YOUR OTHERWISE USELESS HEADSET. ok all you need to do is very carefully remove back cover (undo 1 screw and ease it apart). be very carefull as there are delicate wires inside. lift the inner part out slowly and you will see the battery.it has some orange tape around the end and there is a small circuit board attached to it with a small red wire and a small black wire. look at the battery and you will see under the orange tape there are to larger tags.these are the main battery terminals, peel back the orange tape just until the tags are slightly exposed. now you need to solder a wire to each of them and DON'T TOUCH THEM TOGETHER. on the battery it says which tag is + and which is - make sure you mark your wires or get red and black ones. now i used the lead from the charger. look at it . it has a hole in the center of the pin that is the + so put the + wire in there. if you are not sure use a volt meter. now touch the - wire to the outer metal of the connector that is the - point on the charger connector. hold this for around 2 mins but no more. as the out put of the connector is 6.2v and the battery is only 3.7v the battery will get warm. if the battery is getting too hot in under 2 mins then take of charge. when you have done that and taken off the connector i recommend to use a volt meter and just put it on the battery wires you soldered on to check battery voltage. as long as it reads you should be ok. de solder your wires from the tags and rebuild headset then try and charge it. this worked for me. i am no electronics expert i just like to mess with broken stuff so i know it seems a bit dodgy to connect like this but i had nothing to lose and it worked.
Posted on Dec 01, 2008
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Posted on Jun 09, 2009
SOURCE: I charged the BT350 using the Jabra Charging
wil not take charge if it is the battery how do i fix it
Posted on Jan 03, 2010
  • 16 Answers
SOURCE: problem charging the device
This has been answered on this site try this link
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Posted on Jan 07, 2010
Why won't my battery charge? Charger is good. Was charging and my tablet fell off the bed onto the floor.
Sounds like you have broken the charging port. I would suggest you take the tablet to an authorized repair center to have it repaired
May 02, 2016 | Tablets & eReaders
Charger
If the end of the charger broke off inside your nabi, it will be difficult, but you can get it out. Ideally you still have the broken piece. Superglue the end, put it back in and let it set, then pull it out quickly. If you don't have the rest of the broken piece, you can use something like a toothpick or a cotton swab with the cotton tip removed. Check out YouTube for videos on this. If your charging cord just fell apart and nothing is broken inside your nabi, just buy a universal charging cord. Make sure the tip matches the one you broke. Amazon is a good place for finding these. It will still charge your device.
Apr 16, 2014 | Nabi 2
Major static with bluetooth speaker
With your "new" computer, you get up to 90 days of "free" technical support, via telephone, from Dell. Telephone them.
Feb 23, 2014 | Jabra Solemate Speaker System - Wireless...
Jabra How To Connect to my PC
Hello
Are you prompted to enter a Bluetooth pairing code? The pairing code for the Jabra Solemate is 0000.
Try disabling the Bluetooth on the Windows 8.1 device and then re-enable it and then try the pairing again.
Oct 26, 2013 | Computers & Internet
Usb charging port fell off inside my Aliph Jawbone Jambox Blue Wave Wireless , opened it up and have to find battary cause circit board broke off with port! wtf the usb port is always coming off stuff
A Jambox is a wireless speaker, not a phone. Anyone claiming to know the answer while referring to phones clearly doesn't know what they're talking about.
The question is mis-filed under cellphones, but the respondents so far don't seem to care that it's not a phone at all. :D
Take a look here: https://www.youtube.com/watch?v=X5APtwqtEps
Apparently this is a very common problem with the Jambox, so contact support first and ask them to replace it.
Mar 03, 2013 | Cell Phones
Where can i buy just the outside temperature transmitter, mine fell and broke
have you found a replacement? Mine stopped working and I need a new one too,
Feb 07, 2013 | SkyScan 86709 Atomic Wall Clock
Hello,today my E66 fell in water n got really dameged,i tried to fix its working properly but wen i insert charger my phone is not getting charged, its not charging, battery is ok,but i cannot fiqure out...
Hello there, usually when your mobile device falls in water the last thing you want to do is charge it. At least this should be the situation for about a week. This is so because even though the device might come on the insides are not completely dry and electricity mixing with water inside the mobile device is the last thing you want.
Although if after you are satisfied that the inside of the unit is dried you can try charging again and if it does not charge then your charging port is bad and would need to be replaced.
Hope this solution has been helpful?
Jul 20, 2011 | Nokia E66 Smartphone
Dear, The USB port on my M-Audio Axiom 61 MIDI controller keyboard has broke inside the board, it fell on the cable and the USB broke inside.. Is it possible to send me a new mainboard replacement...
You should be able to get a replacement part for that. Also depending on how tech savvy you are, might be able to open it up and resolder the USB port back onto the board. No idea of the cost of the part however, depends on the manufacturers part list.
May 03, 2011 | M-Audio Mobile USB MIDI Controller
Grinder fell. Black "button" inside broke off.
Use just about any 2-part epoxy, clean parts with rubbing alcohol first to remove coffee oil and get a good bond.
Nov 08, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
Jabra Black SOLEMATE Portable Bluetooth Speaker 1009710000002 Logo
509 people viewed this question
Top Jabra Audio Players & Recorders Experts
Tom Chichester
Jeff Tilburn
Jeff Tilburn
Are you a Jabra Audio Player and Recorder Expert? Answer questions, earn points and help others
