SOURCE: vsx-94txh
If I'm not mistake, it's dependant on you monitor's ability to display 1080p. I believe the defaul setting on the 94TXH is to read the TV's max resolution and anything above will not feed.
SOURCE: Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
SOURCE: Software suite won't install; message states I need a blu-ray rea
pop in the drive (connect it) and install the disk. your computer should pick up the new drive no probs.
SOURCE: When attempting to update my bdp-120 blu-ray
You need to format your usb memory device which will mean that everything will be erased from it so move anything you want to save first. Before you attempt to place the file on the usb device again make sure it has been unzipped first.
SOURCE: I have a bdp-430 Blu-ray disc player from pioneer and it will not read any Blu ray disc
Hello
If it reads and play all other format discs, that is, CD, MP3 and DVD.. The laser pickup unit is faulty. Check your player can read all region DVDs with it. OK.
