Question about JBL Pebbles 2.0 Speaker System 2-Piece
JBL Pebbles just bought the JBL Pebbles and connected them to my PC using the USB cable: I am able to control volume but can't hear a sound! When connecting the audio cable to my iPad it works fine, though... Is the audio not supposed to flow from my PC to my speakers through the USB cable?!? Any advice welcome!! Thx.
5 Suggested Answers
  • 18 Answers
SOURCE: No sound out of JBL LSR25P speakers attached to keyboard
problem could be in wiring, fuse, crossover or the components can be damaged. the original JBL tweeter and 5.25" speaker are no longer available so replacement options would be the only alternative.
cathy@speakerex.com
Posted on Jun 25, 2009
  • 396 Answers
SOURCE: how to install the mounting bracket to JBL control 25?
big red
they allways have a screw in the back you just tighet it and level your speaker
Posted on Oct 23, 2009
SOURCE: Loose mounting brackets on JBL Control 23 Speakers
Remove the JBL badge on the front grill, insert the supplied hex wrench and turn counter-clockwise until it's loose enough to adjust the speaker, the turn the hex wrench clockwise to tighten it. If you don't have the hex wrench, you can use a long allen wrench.
http://www.jblpro.com/catalog/support/getfile.aspx?doctype=3&docid=1372
Posted on Feb 24, 2011
domotek
  • 591 Answers
SOURCE: My JBL eon 15g2 speaker was working fine and then
the braided wires from the speaker connectors to the voice coil could be broken (from repetitive movement) or it could be the voice coil it self that could be cut open from a miss alignment of the cone (ware and tear), delicately push on the cone and feel if it rubs, a simple test is to check the IMPEDANCE of the speaker with a OHMMETER, if you have a reading (4,6,or 8 ohms) than the speaker is fine, check the rest of the wiring, if it reads OPEN than you need a new speaker...
Posted on Apr 09, 2011
How to open these (JBL Pebbles) speakers?!
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Dec 25, 2016 | Audio Players & Recorders
Right speaker has no sound
Check R cable from source to speaker, No power used in L or R cable, they only receive the signal from SOURCE to speaker, You onlly have 2 ends of each cable, 1 to source other end to speaker
Mar 13, 2015 | JBL Pebbles 2.0 Speaker System 2-Piece
Can JBL Pebbles be connected to an iPad mini?
From a customer review:
It also has an aux 3mm input
If you connected the headphone out of the ipad to the aux in on the speakers via a Male to Male 3.5mm cable the speakers would work. The only amplification would be from the ipad, not the then unpowered speakers.
Feb 24, 2015 | JBL Audio Players & Recorders
I used the left hand pad on the control unit to reduce the volume to nothing, and cannot get the level back up again. matthew
  1. Check the power connections on your speakers, make sure that the power LED's on the small speakers are lit.
  2. Make sure the green cable is connected to the computer's speaker port (Usually a green headphone-type jack) and also the the speaker- a similar type jack.
  3. Adjust system volume 2_6_2012_8_52_14_pm.png by clicking, drag volume slider bar up to about 75%, and release.
  4. Turn up speaker's volume using the volume (and bass volume) knob on the main speaker.
  5. Play an audio file. Note that if you are using Windows Media Player, etc. you may need to turn volume up there also.
  6. If you are still having trouble go to start/control panel and select sounds. This will show your installed audio devices. If there are no devices, then please provide the make model, etc. of your computer and I will go from there.
  7. Test the devices in another setting will help identify a hardware problem. For example, test your speakers with an MP3 player, or your computer's CD-ROM usually has a headphone jack; test the audio on your PC with a set of headphones, or another set of speakers. If either of these fail it may indicate a hardware problem. Feel free to post back any additional information and I will try to provide further help. Please include your make, model, and version of windows so I can provide specific info for your PC.
I found the following info on your speakers, which you may also find helpful:
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/OwnersManual/Creature%20OM%20Rev%20A.pdf
Thanks for purchasing my services, and please remember to leave feedback once your problem is resolved.
Feb 06, 2012 | JBL CREATURE II Computer Speakers
First I want to say Thank you for your help and time I hang four of them in each corner of my sound room. The JBL speakers is under the TV on 30 deg. and I use them like central speaker. The sound is...
Your PC sound card, sound properties and any proprietary software managing the sound card all have a piec of this.
Audio entering your reciever via an analog RCA cable to, say, microphone or Line In, have their own volume (and other) controls somewhere in the PC. Find them and crank them up.
Outs are similarly equippped with controls.
Feb 06, 2011 | Pioneer Audio Players & Recorders
How do I connect my radial JBL to laptopp, i.e. how i get the sound from my laptop on the JBL pls?
i need to connect my ipod docking device to my laptop in order listed my music from the laptop louder throygh the device. i bought a usb cable in order to connect the lap top to the jbl device ?
Apr 17, 2010 | JBL (JBLRADIALWHT) Speaker System, Docking...
No sound from speakers
Probably.
Do they connect to the computer via USB or mini plug?
If mini plug, make sure you have the right jack on the back of the computer (there's two)
Then go into System Preferences ... select "Sound" and see if you can select something other than "Internal Speakers" - the computer may just not be aware that you want to use the external speakers ...
Are the speakers powered? Is there a volume control on the subwoofer, or an external fob with a volume control on it? You probably know this if you used them previously with your Compaq computer ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Jan 11, 2010 | HP JBL Platinum Computer Speakers
My volume control was working perfectly fine and i could hear the sound perfectly then the green light on my "logitech" volume control turned off so sudden.I checked the cable's seems like everythings in...
inside the sub theres a small computer chip board. unfortunately with jbl this board shorts out very frequently. short of a disassibly process and seeing a burnt spot on the board, the only other chance may be the power pack wich can be replaced with a 20.00 one from walmart
Jul 12, 2009 | JBL CREATUREIIWHITE Computer Speakers
JBL PLATINUM SERIES SPEAKERS
It is possible, but you may run into a problem with the amplification to be able to hear the speaker. Without knowing exactly what your setup is the best I can say is to attempt to hook them up to your headphone jack and see how well they work. If you don't hear anything, you need an amplifier. If you hear a distorted sound, but volume is not an issue, use the line out jack and see if it is any better.
Jul 19, 2008 | HP Compaq Computer Speakers
JBL Pebbles 2.0 Speaker System 2-Piece Logo
65 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
