Question about Nespresso D300 Espresso Machine
Nespresso d300 leaking
Leaks underneath, cant figure out how to disassemble
    New Friend:
  • 5 Answers
The disassembly is a bit tricky as there are some screws with oval heads that require special tooling.
The web site below has tons of useful information on how to do it and where to find the special tool for the oval-head screws.
http://maultech.com/chrislott/blog/20100627_nespresso.html
The tool is available on ebay for about $10.
http://www.ebay.com/itm/Nespresso-Krups-Service-Repair-Tool-Open-Security-Oval-Head-Screws-/121114184054
I managed to disassemble it by cutting a slot for a flat-head screw driver in the oval screws using a Dremmel tool.
Most of the screws that you have to remove are on the back of the machine. There are three special oval head screws + four torx-head screws + two Phillips screws on the top of the machine.
nespresso d300 leaking - nespresso-d300-leaking-3qewsuavjpfouddo0xkzmjzd-5-0.jpg
Posted on Aug 13, 2015
  • Anonymous Jun 21, 2016
    Hi, could you explain how you removed the top grey lid with the two philips screws? I've tried but something seems to be holding it in
  • 3 Answers
SOURCE: Nespresso D300 says "Fill Water" even after I have filled container.
Even if you fill the tank with water, the machine will display this message when it is empty inside (the pipes, heating element, etc.) You need to prime it: run some water through it by running the steamer/hot water wand.  That should take care of it.
Posted on Oct 24, 2007
Have you tried descaling it. This message displays when it's time to descale and I don't know of a way to turn it off without descaling it.
Posted on Aug 13, 2008
SOURCE: Nespresso D300 + "too close" error message
call the Nespresso Club 0800 442 442
Frog
Posted on Dec 29, 2008
SOURCE: water leaks from the top of the C190 Espresso Machine
in our case the problem was fixed easily: the metal piece in which the capsule sits is screwed in on the top. When it became loose our machine started to leak water from the top. So the problem was solved by retightening it!
Posted on Feb 02, 2009
  • 95 Answers
SOURCE: After a move, my Nespresso D90 sprung a major
Hi! I have found the user guide for your nespresso d90, you have to click on this link and for free it will start downloading your manual ( www.abt.com/documents/19390/d90cb_use.pdf ).
I hope this will help you! Have a nice day! :)
Posted on Sep 02, 2011
NESPRESSO D300 ESPRESSO MACHINE STICKS ON F9 AND DOES NOT PROCEED
My you have to look for f9 in you manual it could be that you have to clean
Aug 06, 2016 | Nespresso D300 Espresso Machine
Nespresso Essenza 90 leaking at the bottom seam underneath the used capsule holder, HELP
Try gluing the seam with lock tight glue or similar plastic gluing compound. Let it dry overnight and try again.
Oct 16, 2014 | Nespresso Essenza C90 Espresso Machine
Nespresso d300 appears tap close and does not brew
It probably need descaling. However, if no water comes out at all, descaling is a bit hard. You may need to take out the pump and dip it in vinegar or another descaling fluid.
May 19, 2014 | Nespresso D300 Espresso Machine
After a move, my Nespresso D90 sprung a major leak. Can anyone provide instructions on how to disassemble the unit and fix the issue or provide information if it is fixable? The leak is more like a steady...
Sep 02, 2011 | Nespresso D90 Espresso Machine
Hi My Nespresso M300 has started tripping the RCD power protector in my house. Any suggestions on how to diagnose the problem ?
Check no water has got into the machine or into the power connector. If the power cord is removable like the one on a kettle with the same connector you could try using this on the machine and see if it works. The chances are there is probably a fault in the heating element allowing current to leak causing the RCD to trip and you may need to have this replaced.
Mar 12, 2011 | Nespresso D300 Espresso Machine
Nespresso D300
Hi. Just go to ant hardware store and buy a set of keys, Tell them what you need, they will sell you a set with all the asst. sizes, Under 5.00. Or take the unit with you and just buy the 1 key.
Jul 15, 2010 | Coffee Makers & Espresso Machines
I need a screwdriver/ special shaped key to dismantle the body to gain access to a water leak. Any ideas?
go to the warehouse or mitre mega store and buy any shape screwdriver or screw bit you need for a couple of dollars
Oct 27, 2009 | Nespresso D300 Espresso Machine
Nespresso Magimix M300
Try rescaling the machine.  The following is a PDF of the instructions:
http://www.nespresso.com/precom/sav/pdf/User_manual_CLA.pdf
Sep 03, 2008 | Nespresso D300 Espresso Machine
Nespresso D300
Aug 10, 2008 | Nespresso D300 Espresso Machine
Nespresso D300 Espresso Machine Logo
316 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
