Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
INEED HELP I NEED A U =SER MANUAL FOR A MOTOROLA MTS 2000
    Brigadier General:
  • 6,966 Answers
A Motorola MTS2000 is a government issue 2-way radio, hence user manuals are restricted. You can try ordering them with Motorola (800‑422‑4210). I was made to understand that manual part number starts with “68” and ends with a “-O”. Version would depend whether you have the I, II, II versions in either VHF, UHF, 800 or 900 MHz.
Since this is your 2nd posting of this model and based on your profile however, I would assume that your requirement is technical in nature (field programming, repair, maintenance, etc), perhaps a Service Manual would fit you better.  It is available   here in pdf. A Spec Sheet is  here  likewise in pdf.
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Posted on Oct 27, 2007
SOURCE:
I need help to locate the program botton on my Motorola MTS 2000 with a keypad
Those radios do not have a program button. They use a Motorola proprietary program and also a programming cable and interface box. Check www.batlabs.com for more info on this.
Aug 08, 2014 | Radio Communications
Motorola MTS 2000
Motorola may be able to tell you if you call them, but they may refuse.
If your radio has a front display, you can put it into test mode to see what firmware it has. If it is 5.44 or higher, then it is FlashPort.
You access the service menu by pushing the button with two dots (on the side above the PTT) 5 times quickly after the power-up beep. If you have no front display this is useless.
Jan 01, 2010 | Radio Communications
How do i program my motorola mts 2000 flashport scanner
Your Motorola MTS2000 is not a scanner but a high-end two-way radio. It requires a computer, special interface box (called a RIB, for Radio Interface Box), the proper cable from the radio to the RIB, and the programming software called RSS (Radio Service Software.)
This is much more difficult than a scanner to program and if not done properly can cause the radio to automatically transmit on frequencies that you are not authorized to use.
Try calling your local Motorola dealer and ask them if they will program it for you for receiving only. They will either flatly refuse or they will be happy to charge you a service fee. Some places are more willing than others.
Dec 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Mts 2000 vhf constant tone
The scan is on and you do not have a scan list programed.
This is the most common problem connected to your post. Hope that helps, Bill.
Jan 02, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola mts 2000
MTS2000 software will operate on Win98 and possibly XP, depending on the revision number you have. Yes, you can clone if the model number is the same. It will clone the entire codeplug of the radio. (Note: you will not have 2 same serial numbers. These are unique to the individual radio.)
Aug 16, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
284 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Gene Pitts
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
