Apple deskjet 842c printing
I have a MacBook Pro laptop and an HP DeskJet 842C printer. The printer will not print in color, only in black. It has always printed fine before. I purchased a new color ink cartridge, put it in the printer, and it did not work. Thinking I had gotten a defective ink cartridge, I purchased another one and put it in the printer. Same problem. It printed in black, but not color. I have heard and read about making sure that your printer isn't set to grayscale instead of color and what to do about that, but when I try to do this on my laptop, I do not have the same drop down menus that I have read about in other posts. I cannot find anything anywhere where I can change it to color instead of grayscale. Hope you can help.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Computers & ... Master
  • 1,633 Answers
Re-install the driver for 842c
Posted on Mar 26, 2017
leroyal
  • 2120 Answers
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Posted on Jan 22, 2009
Dipu007
  • 2110 Answers
SOURCE: The ink light blinks all the time since I replaced the color
The ink light flashes when the top cover is open...check the switch that tells the printer when the cover is closed.
Posted on Feb 23, 2009
  • 214 Answers
SOURCE: HP won't print black, but other colors work. New refill kit...
I purchased a c6180 in Jan 09 have just got the black working fine. After pulling the nachine apart, thinking maybe to soak the head, found micro pump for ink air in black line Run copy black only (took maybe 12x25 times) then head clean Try head clean after 50 copies Voila! Black Cannot rule out that reseating all connections helped
Posted on Apr 21, 2009
pineworks
  • 4041 Answers
SOURCE: My deskjet 842C will not print in color
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
  • 132 Answers
SOURCE: I put in a new color print cartridge in my HP
Extremal method for uncloging: cook printhead in boiling water for 5 min
Posted on Nov 18, 2010
My HP DESKJET 842C prints test page in Black and white only not in color, how do I test my Color cartridge is working or not?
try to do the : You can check the ink levels here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02693389&tmp_task=useCategory&cc=us&dlc=en&lang...
The driver for this printer, when used within Windows 7, is built-in or 'in-OS' so you do not have access to the HP solution center or HP Toolbox.
Printing the self-test report will show how the ink is dispensed and what levels of ink are available. If on this report there is nothing shown, the issue is likely related directly to the cartridges rather than a software issue.
If this is the case, visit this article and browser towards the bottom:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud02948&tmp_task=useCategory&cc=us&dlc=en&lang=...
There are steps on how to clean the cartridges as well as the underside of the carriage in case there is and debris or interferrance causing this issue.
Mar 23, 2013 | HP DeskJet 842c InkJet Printer
How to print a test page on my HP 842C printer
Open up the printer properties in the Control Panel, then click the "Print Test Page" button.
Printer wont print black, it only prints in color, also the printing fades
printing in black
* change the properties of your printer --->> Printer icon-->>Properties-->> select color or black and white grayscale.
fading print
*clean the cartridge printhead through the computer or manually (remove cartridge and wipe with cotton cloth with water). Also, clean the scanner window (glass).
http://printerquickfix.blogspot.com/
Jul 19, 2011 | HP DeskJet 842c InkJet Printer
I replaced my color cartridge but my printer still only prints black and white. What do I have to do to print in color?
if you have cd that came with it ,, uninstall and reinstall should work then,, if you dont have cd,, then go to hp web site and dowload the printer files you need,, hope this help
Aug 11, 2009 | HP DeskJet 842c InkJet Printer
Apr 21, 2009 | HP Office Equipment & Supplies
Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Mar 15, 2009 | HP DeskJet 842c InkJet Printer
Feb 23, 2009 | HP DeskJet 842c InkJet Printer
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
