Question about Acclaim Re-Volt
Re volt back up battery
Need to get a back up battery replace
How do I fix my ups back-up with low voltage output, 175 volts only instead of 220 volts?
I would suggest that the battery is exhausted and needed to be replaced.
Jul 16, 2016 | Computers & Internet
Do I have a battery or charger problem.?
I would, first, suspect the battery. The fix is easy: get a new battery. If it takes the initial charge, you have your answer, and shuld buy another battery. If not, replace the charger.
Since the odds are the battery is at fault, you're back in business. If not the battery, a new charger gets it done. Main thing, you needed two batteries ennyhoo, so if the battery change works, you're where you shoud'a been in the first place. mw
Apr 04, 2015 | Drills
John deere power loader not working
Try jumpering the battery directly to the motors to see if the motors spin, if they don't then replace the motors as needed, if they do spin, then use a multimeter and check for 12 volts at the motor wires when the accelerator is pressed, if its showing no volts then work your way back to the shifter switch and check for volts, then to the foot pedal to find where the power isn't getting through then replace components as needed
Jun 15, 2014 | Peg Perego 12 Volt Rechargeable Battery
2002 toyota prius
Hello, the first thing I would recommend that you buy a repair manual that shows step by step instructions, with illustrations I can't do that here. You'll need some common metric tools and a voltmeter, there are high voltages involved and you will need to wear insulated gloves rated at least to 1000 volts DC to prevent severe injury or possibly death.
The actual replacement is not that difficult:
Disconnect the 12 volt auxiliary battery
disconnect the orange service plug on the hybrid battery and tape the connector on the battery
remove the rear seat and the seat back braces
remove the trunk carpet and the spare tire cover
remove the two orange cables going to the front
measure dc voltage at the terminals where the cables were removed there must be less than 1 volt.
remove the 12 mm bolts that connect the battery to the body including the torx bolt
slide the battery back and have someone help to lift it out.
May 21, 2014 | 2002 Toyota Prius
27.5 volt charging voltage
No, that right. The batteries are wires in series so the voltage is 24v and they need a little high input than that to charge correctly.
Jul 25, 2012 | APC Back-UPS Pro 1400 UPS System
Battery indicator light is on,replaced alternator,had battery tested,belt is tight,what could cause this?
voltage regulator?
bad alternator - yes you may have gotten a bad one.
main fuse.
wiring - did you put all the wires back the right way?
test the battery in the car.
1. voltage at battery not running 10-12 volts
2. votage at battery car running 13-14 volts
if all is well - you may need to reset computer / replace computer.
Mar 25, 2011 | 2003 Ford Crown Victoria
APC BACK-UPS PRO 1100VA 120V does not cold start.
When was the last time you replaced the batteries? These units will not start with old / failed batteries connected, or without batteries connected.
If you have a voltmeter, check the batteries. Your unit should have two batteries harnessed together. if you check the individual battery, you should see just over 13 volts, together should be around 26 volts. if you see less than 12.5 volts, that would be why the unit will not start.
You will have to replace the batteries if that is the case. Your BP1100 takes an RBC 7: moz-screenshot-1.pnghttp://www.refurbups.com/APC-RBC7-Compatiblemoz-screenshot.png
Apr 14, 2010 | APC Back-UPS Pro 650 UPS System
Ups only puts out 80 volts when power disconnects
These type of UPS's put out a simulated sine wave on battery power. When you test these with a regular voltmeter, it tries to read it as a pure "rounded" sinewave and will nearly always report 80 volts, instead of 120 volts. If you test it with a true RMS voltmeter you'll see that it is 120. Otherwise, these units are getting older and the batteries need to be replaced every 3-4 years. Here's a link to a replacement battery: http://www.batteryinternational.com/cyber-power-cps585avr-ups-battery-ups-batteries-f1.html
Sep 22, 2009 | CyberPower Office Power 585AVR...
My 18volt Ryobi battery needs the inside batteries replaced. Is there a cheap way to do it? Can I buy just the inside batteries for my 18 Volt?
Yes you can replace the inside batteries yourself , just take the old ones out and go to Battery world or a similar shop and get replacements then all you have to do is repack them yourself and put them back into the battery case .
Jun 12, 2009 | Ryobi Multi-Volt Battery Charger
Acclaim Re-Volt Logo
Top Acclaim Video Game Consoles & Games Experts
Tony
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an Acclaim Video Game Console and Game Expert? Answer questions, earn points and help others
