Question about SanDisk Sansa e250 MP3 Player
Sansa e250 PLEASE HELP!
A while ago, my sansa was drained of all its charge (accidentally). Now, every time I try to plug it into my computer to recharge it and try to turn it on, the screen (on the sansa) just says "Battery is too low. System Shutdown".
What should I do???
  • Anonymous Nov 04, 2007
    The battery was low and so I plugged it in to charge and tried to start a song up and it started it then just stopped. Now the screen is frozen and when I push the buttons they don't work. Help?
  • wyattsmoma Nov 06, 2007
    Same exact thing... Except ( and I dont know if this matters at all) I have replaced both the battery and the Chord, Still getting the same screen reguardless
  • 3 Answers
MAKE SURE THAT NOTHING IS WRONG WITH THE BATERY
Posted on Oct 28, 2007
  • 626 Answers
The battery has come disconnected from the charging contacts in the back.
Remove the 4 screws, remove the battery from the back and re-insert it.
Best of Luck.
Posted on Oct 27, 2007
My sansa mp3 player will not turn on
This happened to me today, which was what brought me here. Also, when I plugged it in to recharge, my computer didn't even recognize it. The SanDisk troubleshooting said to hold up a power switch, which I didn't have, for 20 seconds. So I held the power button down for 20 seconds. (Much longer than the usual amount of time required to turn on). At first I thought it didn't do anything, but then when I pressed the power button again briefly, my SansaClip woke up, was recognized by my computer again, and in every way behaved normally.
Jul 10, 2010 | SanDisk Sansa Clip MP3 Player
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player has problem with recharging. now dead.
I've had the same problem as you. It probably just doesn't work on that computer. Try plugging it into another one, see if it charges.
Mar 15, 2009 | SanDisk Sansa Clip MP3 Player
Low battery
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............ Just make sure it is not Locked or On Hold and then try to charge it............. Will Work Fine.......... Goo Luck
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
My Sansa clip player was hang & shutdown, its not working right now what i do?
Your Clip never turns on at all? Even when you plug it into the computer?
Oct 04, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
hii
just re plug it and see what happens or.. if you have wall mount charger with a usb connect .. then us it ... and if all fails... open ur player and disconnect the batter for a minute and reconnect it and then put it to recharge...
let me know what happnes..
tc
May 28, 2008 | SanDisk Sansa MP3 Player
Sansa e 260
try to wait for it to be fully charged.... then unplug ur sansa from ur computer if it works already... because as i know some sansa are like that... if its recharging it'll totally turned off or locked....
Feb 28, 2008 | SanDisk Sansa e260 MP3 Player
Can't do anything
It sounds the the hold switch is on..The Sansa c250 Hold Switch is located on the side of the device, and is used to prevent any accidental
operation. Once the Hold Switch is moved to the lock position, all function keys will be disabled.
Buttons on the Sansa c250 will not operate when the Hold Switch is active.
Feb 04, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sansa e250 won't charge
I had the same problem - the player needs to be unlocked (the little switch on top) to be able to charge - pretty stupid if you ask me but what can you do
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
157 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
