Question about Ionic Pro TURBO Air Purifier
Power remains on however air flow seems to stop and then restart
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
Press power, buttons light up and thats it
Try pressing the clean cell now button & check pre filter button at the same time hold buttons down at the same time for about 5 seconds with the air cleaner turned of and blue screen lit
Jan 30, 2010 | Kenmore AC2044-1 Air Purifier
F300E powers up in purge mode, but shuts off when heating
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Dec 12, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Air has stopped flowing
You have stopped breathing. Remove hose from you buttocks region.
Sep 19, 2009 | Sharper Image Air Purifiers
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Not returning to 100%
Reset filter reminder:
Unplug power code.
Push and hold sleep button.
Plug power code while pushing sleep button.
LCD shows "P" than release the button.
Push sleep button and you can see 99% filter reminder.
Jul 09, 2008 | Bionaire BAP1300 Air Purifier
Honeywell F300E not cleaning air.
A newly installed system should still be under the contractor's labor warranty. Call them and ask them to come out to check on the unit and explain what you wrote above. This should cost you nothing and is the best way to get to the bottom of the problem.
Nov 09, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Ionic Pro TURBO Air Purifier Logo
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
