Question about Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
Flashing wrench 8 times - Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
What does eight flashes of the wrench indicator mean on the invacare Pronto m 41 power chair
A flash code of 8 indicates a computer controller problem. Check all the connections at the controller under the rear cover. A rebuild or replacement of the controller is probably necessary. Hope this helps.
Jun 10, 2016 | Invacare Health & Beauty
I vacate m91 wrench flashing 4 times and won't turn off...please help!
The wrench icon flashing is telling you there is a problem with the powerchair. 4 flashes indicates a right motor fault. Go to their site to get an owners manual and it will show the flash codes on page 29 and 30. Not good news for you. sorry. Here is the owners manual.
http://www.invacare.com/doc_files/1141450E.pdf
Feb 23, 2015 | Health & Beauty
How do I repair wrench flash 8
If its a Shark then fault 8 : SHARK Power Module Fault
Check SHARK Connections and Wiring Replace the Power Module
if its a DX fault 8 : Over Voltage Fault
Check Battery voltage is below 32V Check Battery wiring and terminating is secure
Oct 20, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Catalina powerchair 8 wrench flashes
8 flashes on a invacare means controller fault,please contact dealer,and have a tech look at first so they can ordor u one,recomdation take chair to dealer if u can will save u money on a house call
Dec 21, 2013 | Electric Mobility Pronto M41 Power Chair...
What the maximum working torque for a Ingersoll Rand 1/2 2705P1?
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
Mar 28, 2011 | Ingersoll Rand Air Tools & Compressors
WRENCH LIGHT
hold down the c and 8 key this will give you a code give me the code i will tell you the fault
May 10, 2010 | Toshiba 1370 Black and White Copier
I have a toshiba 1370 copier....the repair wrench is flashing and won't let me continue, how do i get the wrench to stop blinking?
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
Nov 13, 2009 | Toshiba 1370 Black and White Copier
I need to change the alternator on a 2001 ford focus and need to know what size wrench is needed to loosen the timing belt tensioner enough to remove the timing belt. Please help
I don`t know the size,but it will be metric.If you have a standard,american set of wrenches,get the one that is closest to fitting the bolt head.Here is something to help you decide what the actual metric size wrench to use.8mm is 5/16,,,10 mm is smaller than 3/8.11mm is a 7/16.12mm is larger than 7/16 but smaller than 1/2.13mm is 1/2,14mm is 9/16,15 is bigger than 9/16,but smaller than 5/8.,,5/8 is 16mm.17mm is 11/16,18mm is bigger than11/16,but smaller than3/4,19mm is 3/4.I hope this helps.
Oct 30, 2009 | Ford Focus Cars & Trucks
How to change the spark plugs
if its your first time you need a haynes repair manual.you need a spark plug boot puller.you need 3/8 ratchet wrench.spark plug sockets.from size 5/8 to 13/16.you probably need size 5/8 socket.you need extensions different sizes.and universal joints.to reach hard to get plugs.you need torque wrench. and spark plug gap set.
Jul 07, 2009 | 2002 Kia Sportage
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
