Question about NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
Have had the N600 WNDR3400v2 installed for over a month and all worked well until yesterday. I have an internet connection and the router info says all is good, i cannot get it to connect. I've tried unplugging and plugging back in, deleting the install and reinstalling and nothing seems to work. I have noticed though that when i initially installed, the blue light on the side panel use to blink but now it stays a solid lit blue. I do not know if the issue is with the router or the cable company and in either case, do not know how to fix.
  • NetGear Master
  • 2,219 Answers
The blue light indicates the wireless network is working, it is just that nothing is connecting through it.
The internet icon should be solid green or blinking green which shows it is connected to the Internet, if not connect your ISP.
Posted on Mar 08, 2015
SOURCE: I installed netgear adapter WG111v3 and I keep losing internet connection
I had the same problem and when checking the properties of the adapter under device Manager.
I found the under the Power Management Tab the option to
"Allow the computer to turn off this device to save power" was turned on.
Remove the check mark from this option and click OK.
Posted on Apr 06, 2009
redhaze89
  • 854 Answers
SOURCE: Netgear wireless N USB adapter wont connect to my netgear router
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
For wireless N USB adapter
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Posted on Aug 16, 2009
anandg27
  • 1272 Answers
SOURCE: Netgear wg111 usb 2.0 won't connect even after clicking repair
Hi, Follow the steps below to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Posted on Sep 02, 2009
SOURCE: My Netgear WG111v3 cannot connect to internet
You need to do some wireless setting on router,
Please follow steps to fix your issue
1.Please changed network (SSID)name of router
2.Reinstall adapter driver
If you follow above steps defenately your issue would be resolved
Posted on Apr 26, 2010
  • 89 Answers
SOURCE: I just got a NETGEAR n600 dual band router, ran
My Friend ,
Seems that the router is producing the wireless signal the problem is only with the computer.
What i can suggest you is to delete all the wireless networks from the list and then try to add the network again.
Posted on Dec 09, 2010
What is the purpose of the WPS button on the NETGEAR N600, Model WNDR3400v2?
That is for pairing printers and other router based equipment. Instead of typing the key code.
Jan 19, 2017 | NetGear Computers & Internet
How do I reset my password to factory settings?
The reset procedure of a router, is most of the time printed on the underside of the router. Most of the time you have to push a button for a certain time, or unplug it form the power for at least one minute or so. Page 120 of the manual says:
25666674-430tztikrat04csse0ovhla5-5-0.png The complete manual you find here:
http://www.downloads.netgear.com/files/GDC/WNDR3400V2/WNDR3400v2_UM_23JAN2013.pdf
On page 120 you also see what settings are in the router. But perhaps you need it, to setup everything from scratch.
Apr 26, 2015 | NetGear N600 Wireless Dual Band Router
N600 error 651. My n600 is hardwired to my desktop. my wireless internet connections work fine. The desktop connects to the router no problem, but will not connect to internet. I used the pc yesterday...
If the wireless connects to the internet then the router is fine. Look at re setting the connection on the PC. You might want to check for an update on the driver for your network interface card first.
Feb 20, 2014 | Computers & Internet
How do I connect my HP Photosmart C4795 Printer to my new Netgear N600 Router?
Hello Janet,
Please click Wireless printing center to access more info on how to connect you printer to a netgear router ( wireless )
Dec 23, 2013 | NetGear N600 Wireless Dual Band Router...
My new HP desktop is asking for PIN of wireless router. My router is Netgear N600 WNDR3400v2. All I can find is two MAC #'s and the S/N. Where is the PIN?
This router does not use any type of PIN. You may be confused as the HP wireless networking setup may be asking for the "password", or WPA2 key that secures the wireless network. This must be entered before the router will accept the client and assign it a network IP address. The WPA2 key is stored in the router under the Wireless Settings Option. Unfortunately, if you don't know the key, going there won't help you as the key is not visible.
Nov 05, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Need to connect both d-link dcm-202 and netgear n600 to mac
is the negear n600 model WNDR3400 or WNDR3700?
try setting the netgear in Accesspoint mode.
(guide available here netgear website)
http://gestyy.com/qXchmK
Jul 02, 2017 | NetGear N600 Wireless Dual Band Gigabit...
Just purchased belkin play n600 and am having trouble with setup. Everything loaded, but I cannot access the Internet from my pc now, my iPhone and xbox can connect but the pc the router is connected to...
ok what you will have to do is go to control panel and unistall all the software for the belkin then you will have to reinstall the software when you install make sure you only hook up the router to the computer and get it to work then you can hook up the xbox and the ipone you will have to set up port forwerding for the xbox to work correctly.
B52computers
Chris Thrash
Jan 22, 2011 | Belkin Play N600 Wireless Dual Band N...
My internet keeps goin on and off with my new netgear N600 wireless dual band router. is my home too large for this unit? any help or suggestions? thanks.jomanfitz3@aol.com
Never buy Netgear. They design product so it won't work unless you pay more for technical support. They told me the technicians during the 90 day warranty are not good enough to fix problems, so you can't get solution until warranty runs out and you have to pay extra!
Nov 26, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
80 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
