Question about Microwave Ovens
My microwave won't heat
Kenmore over the range microwave model #721.85032111, will not heat, everything else works fine. It will run like it's heating, but is still cold.
MicrowaveSvc
  • 9047 Answers
SOURCE: kenmore microwave doesn't heat up
The most likely causes are a bad door switch, a loose connector on the magnetron, or a bad magnetron. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Here's a reprint of one of our FAQS on the subject: Q. My microwave seems to be running okay, but it won't heat. A. If you are a do-it-yourselfer with the right equipment and care, you can do quite a bit of troubleshooting, but once you get near the high voltage section, it is time to be VERY sure of your actions. DANGER: Microwaves produce lethal voltages. They can kill. Before you go any further, you should read the safety warnings here: http://207.234.249.73/mwd/safety.txt If you find line voltage (100-125 VAC) on the primary of the high-voltage transformer while the oven is running, the problem is indeed in the high voltage section. If that line voltage is not present, then the problem is not in the high voltage section. Door switches would be one suspect, as well as a control panel problem. To check door swithces, see this file: http://www.microwavedisplay.com/doorsw.txt If you have or suspect control panel problems, see details of the repair service here: http://207.234.249.73/mwd/index.htm There are a few prime suspects to be aware of in the high-voltage section, mainly the high-voltage rectifier diode, the magnetron, and the high-voltage transformer. DIODE: Did the oven pop during the cooking cycle? If so, that's pretty good evidence that the diode has gone bad, not that's not the only way it can fail. High-voltage rectifier ID & diagnosis can be found here: http://www.gallawa.com/microtech/diode.html MAGNETRON: Sometimes everything looks and seems okay, but the magnetron is simply not producing heat. At other times, it may be arcing inside, and producing a noise that sounds something like someone growling into a coffee mug. It's also possible that the mag may have a cracked magnet. Check for that, too. More likely, it may be that the magnetron filament connectors have loosened (they should be snug) and, due to resistive heat, the terminal connections have deteriorated and burned loose to some degree. A photo showing that area can be found here: http://207.234.249.73/mwd/magterm.jpg . Here are some tips if you have loose connections: If the connectors feel loose, and any burning or melting seems minor, you should be able to carefully tighten the connectors with a pair of pliers, then sand or file the rusty-looking terminals of the magnetron until they are clean and shiny. If the burning is more serious, the connectors may need to be replaced. They can be obtained from home improvement centers and auto parts stores. They are 1/4" connectors and can be squeezed in place onto stripped wire with proper crimpers or a pair of pliers. Another option is to cut the connectors off the wires and solder the wires directly to the magnetron terminals. If this is done, do not apply heat to the terminals any longer than necessary. If the burning is really bad, the plastic surrounding the magnetron terminals is charred or melted, the magnetron may need to be replaced. HIGH-VOLTAGE TRANSFORMER: When the voltage transformer fails, it will often emit heat and smoke, but with the fan running, you might not smell it. With the cover off, it may be easier to smell. Also, you can look at the windings and see if they look discolored due to heat. If a high-voltage transformer is shorting, it can blow the fuse a few seconds after pressing the start button to start a cooking cycle. High-voltage transformer ID & diagnosis can be found here: http://www.gallawa.com/microtech/xformer.html HIGH-VOLTAGE CAPACITOR: The high-voltage capacitor will usually fail by shorting. When it does, the fuse will be blown right after you press the start button to begin a cooking cycle. If the capacitor is old and dries out, then it can fail by just not allowing the high-voltage to be doubled. I don't remember having ever seen this condition. High-voltage capacitor ID & diagnosis can be found here: http://www.gallawa.com/microtech/cap_test.html More information on the high-voltage circuit can be found here: http://www.gallawa.com/microtech/doubler.html Again, be safe!
Posted on Feb 25, 2007
rickzilla
  • 706 Answers
SOURCE: ge microwave won't heat everything else works fine
Hello t_sumner4756,
Everything else can work perfectly fine but if it doesn't generate microwaves to heat your food than it is not working ( you knew that anyway).. Unfortunately, and in most cases when you microwave stops working in that manner..the components at fault are either the Magnetron, Filament PS or a High Voltage Capacitor..What that means is that you are probably better off just replacing the entire appliance rather than attempting to repair it. If it is a year old or less, bring it back to where you purchased it and have them replace it.. I am sure that is not what you wanted to hear but when the cost to repair exceeds the cost to replace... it just isn't worth repairing.. Plus.. there is an element of danger associated with these kinds of repairs...
Regards,
Rick
Posted on Nov 22, 2008
drumbanger
  • 1199 Answers
SOURCE: Over the range Frigidaire Microwave not heating. Model FMT148
This is a sure sign that the MAGNATRON needs replaced (this is what heats up the food) if every thing else works but food not cooking! 99% of time it is the magnatron!
Please rate answer!
THANK YOU!
Posted on Jan 13, 2009
  • 1214 Answers
SOURCE: Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Posted on Jan 24, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp microwave oven model r-1440 runs, but doesn't heat food
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you have, I would most strongly suspect a bad magnetron or a loose and possibly corroded connection on the magnetron's terminal.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it'sprobably okay)
http://www.gallawa.com/microtech/mag_test.html
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Posted on Feb 08, 2009
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Kenmore 721.80403 microwave won't heat
If the turntable does move as well it is likely the inverter (power) or the Magnetron itself.
Nov 03, 2012 | Kenmore Microwave Ovens
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
I have a kenmore over the range microwave oven.Everything on the microwave works but it does not heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 28, 2011 | Kenmore Microwave Ovens
Kenmore microwave model 721.80033700 won't heat
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 21y/o full sized Kenmore 700w microwave that I want to keep. Worked fine until this morning. Everything works except the heat.
Sadly Kenmore only offers parts for 10 years. The truth is a new microwave for 50 dollars will be much more energy efficient than your 21 yr. old model
Jul 12, 2009 | Microwave Ovens
My Kenmore over the range microwave is not heating....
chances are your magnatron quit on you and you may be better off getting a new one.
Apr 05, 2009 | Kenmore 62622 Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
