Question about Heavy Machinery
Electric switch for altrad/liv lescha pro150 - Heavy Machinery
Need parts for Lescha Zak 1800 Chipper/shredder
I have a used lescha zak 1800 chipper. It does not have the stand. I have the motor with the on/off switch and most of the chipper housing. IThe motor runs strong. Reply at asm3davis@yahoo.com.
Sep 02, 2012 | Yard Machines Electric Chipper/Shredder
Lescha Hobby 125 S electric mixer requires new drum main bearing
I had a similar problem on a Lescha Hobby Mix 120 SF. (Sounds similar to yours) The failure seems to have been caused by corrosion of the ball bearings. If you get water into the rear bearing housing when it is operating, and then store the mixer with the opening in the drum downwards, the water collects around one of the bearings. The bearings are a standard size ball bearing with a 62mm outside dia, 30mm bore and 16mm wide. I bought the sealed version from a local bearing supplier (or look one up on the Internet). The original ones fitted are unsealed, which is part of the problem. I also bought two new bearing retaining external circlips for a 30mm shaft. I had a paint round inside the housing with hammerite, and drilled some 10mm dia drain holes around the outside of the housing near the bolting flange. I also store the mixer with the drum horizontal now.
May 27, 2011 | Gazillion Cement Mixer
Heavy Machinery Logo
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
