Question about Gateway FPD2275W LCD Monitor
Monitor picture my monitor displays poor pictures which are not visble,i dont know if its the system unit or monitor
HP w1907 monitor has fuzzy text
Procedures of acquiring high definition pixel quality
1.power on the computer wait until the desktop of icons display after booting has been completed
2. using the arrow of the mouse or pointer to an area on the desktop without icons, right click to display a prompt list
3. locate the appearance and setting prompt on the list.
4. a click to provide the options to increase the picture quality termed pixels
5. LCD monitors could produce several thousand pixels, select a choice nearly approapiate for reasons explained
a. the highest selection of picture quality provided on the list for a monitor powered by a separate computer with extremely dense graphics like known for modern gaming could cause monitor to blank out as precaution.
b. when selecting a picture quality from the list provided on the appearance settings area after a right click on the desktop, be sure about the compartibility of the monitor and computer unit, explained
c. most modern retail provide system units with higest definition pixel capabilites for several funcitons as gaming graphic and design, connect such a unit to an old monitor would display low quality definition pictures. However, that could be fixed by adjusting the appearance setting only with caution not to select the most highest available from the list of pixels.
Dec 06, 2010 | HP w1907 LCD Monitor
Picture is not displaying in the monitor.
Please look here: http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
It is common problem with this model, poor/contaminated solder joints. It can cause the transistors to go out also. You must remove the old solder, clean the inductor leads real well and then resolder. I fixed close to hundred of this model. There was recalled by HP because of many failed units out there, but it is too old now.
http://www.amazon.com/HP-Pavilion-F1703-LCD-Monitor/product-reviews/B0000A039V
Apr 04, 2010 | HP Pavilion F1703 17" LCD Monitor
Monitor not work(dont have a pictures)oly a sound
The LCD is bad in this unit you would need to replace this unit (RARE) part but you can find them on ebay!! But other then that its the display in the unit that has gone out on you.
Thanks and please leave postive feedback for your totally free answer today!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 20, 2009 | Sega Game Gear Console
Color bars only on KWorld PC to TV - Composite and SVideo
found this reference it may be of help
This product appears to be defective. I connected it to a working video camera that produces an excellent picture on a standard monitor. I looped the video from the camera through the monitor to the converter which is connected to a new ACER LCD display. The LCD display workes perfectly when connected to my computer. Using the converter, the results are poor. You can see the desired picture in the background but in the foreground there are horizontal bars that scroll vertically through the picture. I'm returning it for an exchange - will try again.
Jul 26, 2009 | KWorld PC to TV (0872880887527) Video...
Ned to find the right adapters and drivers to fix poor display
This monitor albiet old can do a whooping 1800 x 1440 resolution. I don't think that the monitor is your problem at this point but your Video card. What type of video card do you have in your system and are the drivers correctly installed for them. You can find the drivers for the monitor at http://tom.viewsonic.com/support/drivers/drivers.cfm?category=3&formName=monitor
May 22, 2009 | Nokia 445 Pro 21" CRT Monitor
Non crispy display
Six to seven years is about the usual life of a picture tube, and then you start seeing signs of aging. Poor focus is one common symptom (the loss of crispness you noticed). There is an internal focus adjustment, but it usually can't compensate for the tube. If you want to try it, the control is on a part called the flyback transformer. It's usually found on a rear corner of the circuit board, and has a red wire going to a rubber contact cap on the picture tube. Most flybacks have two little knobs on them, and you want to tweak the one marked "FOCUS" a little to see if improves the picture. BE VERY CAREFUL! WITH THE POWER ON THERE ARE POSSIBLY LETHAL VOLTAGES EXPOSED!
If the focus adjustment doesn't help enough, it's time to look for a sale on an LCD monitor. The prices have come way down, and eBay is a great place to look for deals if you don't want to buy new.
Jan 27, 2009 | LG Flatron 775FT 17" CRT Monitor
No picture
If you mean you hooked up an external monitor and you want to see the display there. Well there should be a Fn key combo to toggle the displays. It should be one of the keys that looks like a monitor plus the Fn key at the same time. Otherwise go into the Control Panel -> Display -> Settings and you can switch to the other monitor there. Hope this helps.
Jan 18, 2009 | HP Compaq Presario v4000 Notebook
Distorted picture on 20 inch monitor
second problem some unit on the board in the monitor has gone bad return it for an exchange
first problem the display setting need to be set correctly
Dec 28, 2007 | Acer AL2016W 20" LCD Monitor
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Gateway FPD2275W LCD Monitor Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
