Question about Arcade Raw Thrills Big Buck Hunter Pro Video
Big Buck Safari Loading please wait, never loads. Reinserted DVD and loaded hard drive again. Computer chevcks out. Notice the Bios does not show USB Device or USB zip has selection! It does reconize
Bios does not show USB device to select order of booting. Deli computer 330. Does the game require the boot from usb then hard drive to get going?
4 Suggested Answers
  • 5 Answers
SOURCE: when big buck hunter pro is turned on I'm getting
Reimage the hard drive by opening the DVD drive door and inserting the recovery disk, which is obtainable from a distributor such as Betson in the US. Close the DVD drive door and power the game off then on again. Follow any on-screen instructions as the software installs. If this procedure fails or the game still gives trouble, you may have a failing hard drive. You could attempt replacement yourself if you feel up to it, or alternatively send the entire computer unit to a distributor or specialist dealer for testing and possible repair as necessary.
Posted on Jul 30, 2010
SOURCE: When turning Buck Hunter Pro on i am getting an
probably need to reload the software using the restore disc
Posted on Jan 10, 2011
bugoy31
  • 1238 Answers
SOURCE: Big buck safari: While
Good day!
That question is exactly on my expertise because I'm arcade and amusement technician.
If your arcade is auto shut-off or reset this thing you have to do.
  1. Go to the back of the machine and open the back cover to reveal the internal parts.
  2. Try to look at the power supply board.
  3. Plug-in and power it ON to perform voltage data.
  4. Check the 5vdc on the power supply and on the input voltage of the board using multimeter tester (range in DC).
  5. It should have 5.10vdc,if the voltage is less than 5.10 adjust the voltage trimmer located on the power supply board.
  6. After you adjust the voltage,you have to reboot the machine by powering off and after 10 seconds power it on again.
I hope this solution will be helpful.Thank you and good luck.
Posted on May 12, 2011
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Free usb reboot
You might want to boot from a USB device, like an external hard drive or a flash drive, for many different reasons.
When you boot from a USB device, what you're actually doing is running your computer with the operating system that's installed on the USB device. When you start your computer normally, you're running with the operating system installed on your hard drive - Windows, Linux, etc.
How To Boot From a USB Device
Change the BIOS boot order so the USB device option is listed first. The BIOS is rarely setup this way by default.
If the USB boot option is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at any boot information that might be on your USB device.
Tip: The BIOS on most computers list the USB boot option as USB or Removable Devices but some confusingly list it as a Hard Drive option, so be sure to dig around if you're having trouble finding the right one to choose.
Note: After setting your USB device as the first boot device, your computer will check it for boot information each time your PC starts. Leaving your computer configured this way shouldn't cause problems unless you plan on leaving the bootable USB device attached all the time.
Attach the USB device to your computer via any available USB port.
Note: Creating a bootable flash drive or configuring an external hard drive as bootable is a task in itself. Chances are you made it to my instructions here because you know whatever USB device you have should be bootable after properly configuring BIOS.
  • Restart your computer.
  • Watch for a Press any key to boot from external device... message.
  • On some bootable devices, you may be prompted with a message to press a key before the computer will boot to the flash drive or other USB device.
  • If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS (see Step 1) which will probably be your hard drive.
Note: Most of the time when trying to boot to a USB device there is no key-press prompt. The USB boot process usually starts immediately.
  • Your computer should now boot from the flash drive or USB based external hard drive.
Jan 02, 2015 | Computers & Internet
How can I retrieve the data in my portable hard drive. It says I have to format the drive.
You didn't give much detail as to what happened, but I will suggest what I can. It sounds like you have a corrupted partition which may give you a chance to pull that data off the drive. After your data is saved delete the partition and reformat.
>First, if you have a USB cable connection, exchange the USB cable for another; I have seen bad cables do this.
>The second thing to try is to access your drive from outside Windows; use the link HERE to download Reatogo. Reatogo is a program that loads from your DVD drive and by-passes Windows and loads into memory. You can then "see" your hard drive and attempt to access your data. It has a Windows XP screen so it is easy to navigate around in. So, do this:
>Download from the above link
>Double-click the file and burn to a CD
>Make sure your BIOS is set to CD=1st Boot Device (the BIOS checks the cd for bootable files before loading Windows).
>Reboot with the CD in the DVD drive; this takes a long time to load so be patient. You may think the load has stalled, but it hasn't. When finished loading, you will see a duplicate of the Windows XP desktop, and your hard drive will be listed. Click on it, and if the hard drive is still working you will see your C:\ directory. Plug in a flash drive, locate your data, and drag & drop it onto the flash drive..
If that doesn't work, post back for additional things to try.
Wish you the best!
Oct 13, 2013 | Western Digital My Passport Essential...
My Levono G470 problem
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 01, 2013 | Computers & Internet
Tried to boot from USD, CD/DVD Drive but failed. Still showing No bootable device -- insert boot disk and press any key
To boot up from the DVD drive go into the BIOS setting - boot device order and move the DVD as the first boot device and the hard disk as the 2nd boot device.
If you want to boot up with the USB then move the USB as the first device. If the USB is not listed as a boot device then it is not possible to boot up with an USB device.
May 26, 2012 | Acer Aspire 4930-6862 Laptop
Gx3 will not accept new windows
load or insert your windows operating system DVD then restart , while up coming boot press DELETE or F2 , so can go to bios then press system 1st boot DVD second boot is HARD DRIVE ,disable Floppy drive then press F10 to save changes and exit , automatic will reboot itself. wait till you see prompting press any key to boot DVD. thats it
Apr 22, 2012 | MPC Computers TransPort GX3 Notebook
When start my laptop, get an error msg. "Grab loading 1.5, please wait.. grab loading error 17. and i can not boot from cd / dvd too..in HP nx9010. Plz help me.
This grub loading error 17 means that the file system type could not be recognised you should be able to boot from a cd make sure the cd or dvd drive is enabled as the first boot device in bios
I hope this helps
Andrew A
Apr 01, 2011 | HP Compaq Business Notebook NX9010
How do you wipe a computer with windows xp, without the cd or a floppy. there has to be a way to use a usb. (computer wont boot passed welcome screen). don't need to save xp either.
If your system supports it you can go into your Bios (right when computer starts booting up you press (usually "Delete" key) to enter Bios setup.
In the Bios you go to Boot devices, any devices set up for booting will show in a list in numerical order, this order is the order your system gives preference for booting. Most times you will see your hard drive and your cd drive already there. Select the first one and open the pop up menu for it (on the right side of the screen it should tell you what key to hit to change the value), if your USB device is there then select it to be your first boot device. Then hit the key for that 'Exits and Saves Changes' (usually F10). This exits Bios and starts your system booting up again.
Before you boot up though you need to have your memory stick set up with either Windows Install files (i.e. burning the windows install disc to your usb device) or format your USB device to be a boot disc (this will only then allow you to boot to a DOS prompt though and you would still need the Windows files)
Feb 19, 2011 | Microsoft Windows XP Home Edition
I can't seem to get my HP DV1000 laptop to boot from USB I go into the bios and it shows it as a hard-drive but it won't boot from it. I've made a Flash drive with bootable Ubuntu 10
Start up the computer and hit F10 a few times during start-up and login to the BIOS and check that the USB drive precedes the hard disk and CD/DVD drives in the boot order. Use the + and - keys to move the boot devices up or down within the boot order. After you have completed this, hit the ESC key and then choose Select Save Changes and Exit. The computer will now attempt to boot from the devices in the order you have specified.
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 22, 2010 | HP Pavilion dv1000 Notebook
Arcade Raw Thrills Big Buck Hunter Pro Video Logo
77 people viewed this question
Top Arcade Toys Experts
ray gallant
Are you an Arcade Toy Expert? Answer questions, earn points and help others
