Question about Epson Stylus CX7000F All-in-One Printer C11C676001
Cleaning epson cx 7000f print rollers - Epson Stylus CX7000F All-in-One Printer C11C676001
Metawatch
  • 96 Answers
SOURCE: Epson cx 6400 not printing colors
Chances are you are running out of ink or need to do more cleaning cycles.
Its also possible that your ink is "Very Old" and may be slowly becoming clogged in the cartridges.
Posted on Feb 09, 2008
Ajkill
  • 2035 Answers
SOURCE: Poor quality or no color in print or scan mode
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.If cart as the print head separate then remove the print head and follow the procedure ...
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 16, 2009
  • 191 Answers
SOURCE: Epson Stylus DX 7000F
http://driverzone.com/device.php?id=73871
download driver from here then install but frist remove old driver may be ld driver has some problem.also reconct all connection of printer like
serial cable or usb cable.
Posted on Mar 04, 2009
SOURCE: Epson cx8400 Black Ink Cartridge doesn't work on Printing
I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
Posted on Oct 14, 2009
cns assoc
  • 677 Answers
SOURCE: can't locate how to clean print heads on my Epson
Hello, to clean click on start, then click on printer & faxes, then double click the icon Epson CX4800, until it opens. You will see the printing que. Click on printing preferences then select the maintenance tab.
See below., and hope it helps.
Good Luck :0) HERE ARE 2 DIAGRAMS.
Posted on Nov 07, 2009
I have an Epson CX4200. The self cleaning heads usually help when run. BUT lately black dots are appearing and smudges on the printouts. The slef cleaning doesn;t hcure it and wiping out all excess ink...
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 04, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Cx 4800 not printing quality colors
Are you using Epson Genunie Cartridges?
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 22, 2010 | Epson Office Equipment & Supplies
Epson stylus 7000F, unused for several months Changed cartridges on unpacking, but wind up with a dis-coloured band acoss the print when printing. I have tried the menu-driven head cleaning process, with...
remove all the catridges and clean with tissue paper also you can try to clean with boil water .just clean the nozzle and see .if you success then good otherwise you need to change the catridges.
Nov 24, 2009 | Computers & Internet
Can't locate how to clean print heads on my Epson Stylus CX 4800
Nov 06, 2009 | Epson Stylus CX4800 All-In-One InkJet...
My cx 3200 is not printing correctly. It prints
I had that same problem, when I used Generic INK.
Replace the cartridges with Genuine Epson Ink,
and then ran fine.
Weird eh?
Good Luck.
Nov 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx 8400
Start, Click Printers & Faxes. Right Click EPSON CX 8400.. Find & Click Printing Preferences. Select the Paper Size (Choose what printing size you want). GOOD LUCK!
Pls! Don't forget to rate me.
Mar 04, 2009 | Epson CX8400 All-In-One InkJet Printer
My epson cx 9400 will not pull paper in when faxing thanks robertj463
Hi.. Have you tried cleaning the pickup roller?... after use the paper dust covers the roller and the paper slips... does the roller attempt to pickup the paper?.. is there some bits of paper stuck in the paper path?
Thanks
jim
Feb 18, 2009 | Office Equipment & Supplies
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Black ink not printing
You have to run a head cleaning cycle:
Follow these steps to clean the print head:
  1. Make sure the Stylus CX is on and the cp_light_183_er.gif ink light is off.
  2. Hold down the cp_button_48_er.gif ink button for 3 seconds until the cp_light_1.gif On light starts flashing. The Stylus CX runs a head cleaning cycle and the cp_light_1.gif On light flashes.
    alert_caution.gif Caution: Never turn off the Stylus CX while head cleaning is in progress. You may damage it.
  3. When the cp_light_1.gif On light stops flashing, turn off the Stylus CX.
  4. Load letter-size paper in the sheet feeder.
  5. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds. The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown below are some examples of what the nozzle check may look like:
    Nozzle check pattern with no gaps im_158_er.gif Nozzle check pattern with gaps im_159_er.gif
  6. Examine the nozzle check. If it does not look like the nozzle check pattern with no gaps as shown above, repeat steps 2 through 6.
alert_note.gif Note: If you don't see any improvement after cleaning the print head three times, turn off the Stylus CX and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
If you do not use your Stylus CX often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Oct 24, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus CX7000F All-in-One Printer C11C676001 Logo
13 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
