No, television don't generally have a reset button. Disconnecting from the mains power at the wall outlet for 10 minutes and holding the power button for 60 seconds is the reset. Or this which clears stored settings.
How do I restore my Silo TV to the original factory settings? Press the menu button on your remote. Go to options > reset > execute.
Unfortunately you can't. This is not a Smart television and is not connected to home wifi. If it was, you can get the app from your service provider and connect to the television via wifi.
You can't use your phone in its own because it doesn't have an infra red transmitter.
Yes, all televisions can be repaired. Just take it to a local television repair shop. Probably a power board issue, but these things need proper diagnostics.
www.bestbuy.com > site > silo-digital-32-class-720p-60...
Oct 14, 2009 - it finally diedI and I needed a new TV and I had no money. Then it became too much to ignore, so I sprung for $339.99 (<370 in CA with tax) for ...
Rating: 4.5 · ‎2 reviews · ‎US$299.99
PDF
We recommend you register your SILO 32" HDTV either at ... *When moving the LCD TV from an area of low temperature to an area of high temperature, ...
Mine had the same problem. If you go into the menu --> Parental control, type in default code ( 0000 or 8888) --> Then check the front panel lock to make sure it is on
This should fix it, it worked for mine.
my tv is doing the same thing i am fighting with wal mart right now my tv was only 1 year old on day i tryed to turn it on and it would not so im trying to get to the biottom of it right now call this girl named lalasha at 479 204 6805 she might be able to help u
