Question about Hoover WindTunnel Pet Rewind Upright Vacuum
Vacuum shut off wont restart
Windtunnel Pro
2 Suggested Answers
carlsbiz
  • 1124 Answers
SOURCE: Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
Vacuum shuts off while in use
There is a thermal reset inside the motor that shuts it off. There may be a clog.somewhere or something restricting the airflow, it could be clogged filters. If there are no clogs or restrictions it is possible the thermal reset is bad in which case you will have to replace the motor.
Jan 26, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
Jan 11, 2010 | Euro-Pro UV209 Upright Vacuum
Wont shut Off
its the power switch, hoover has had that problem for years. I'd take it to a vac repair shop, sometimes the wires that connect to the switch get burnt as well and should be replaced.
Sep 16, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover windtunnel bagless shuts off when warm
it is a heat thermostat in the motor.
contact hoover or a local dealer
Mar 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
The shut off switch is stuck to the on position
This sounds like you have an internal problem with the electrical switch. I would recommend you take it to a vacuum dealer who has experience with this model. This is a relatively simple reapir for a pro shop to handle.
Jan 13, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Deluxe windtunnel by hoover
Check for a clog in the hose or the dirt inlet by the brush roll. When there is a blockage, the thermo protector will shut the motor off to protect it. That protector could be bad, or a problem with the motor. Is the brush roll turning freely and or is it froze up and won't move.
May 25, 2008 | Hoover Windtunnel Deluxe U54219RM Vacuum
Simplicity vacuum
just take it in to your vacuum store.
Mar 08, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hover mach 4 vaccum
usually caused from being plugged, so first find the plug and clear it. The motor has an automatic reset, should restart after about 30 minutes, if it continues to shut off, there is still a plug.
Dec 12, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover WindTunnel Pet Rewind Upright Vacuum Logo
46 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
