Question about Kitchen Ranges
How to use self cleaning in kenmore oven
Model# 79093751100
  • 60 Answers
SOURCE: self cleaning oven instructions
you can google it or just push the clean button and it will most likely default to 3 hours and all you have to do is push start and after it is done wipe out the ashes with warm soapy water DO NOT USE OVEN CLEANER as this will destroy the finish of the self clean cavity
Posted on Nov 12, 2008
SOURCE: ROPER ELECTRIC RANGE SELF CLEANING
how long to leave on to self clean
Posted on Apr 18, 2009
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: We used the self cleaning option on our Kenmore
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Self Cleaning
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Posted on Sep 26, 2010
Kenmore 629
Could be the lock needs replacing the oven won't self clean if the door lock isn't functioning it's a safety thing so you don't get your face burnt .
Ray
Apr 16, 2014 | Kenmore Cooktops
How do I clean Kenmore electric range model; 36393091300 .No manual for this self cleaning range.
Hi,Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Where can i get cleaning instructions for a Kenmore model 4652591 self cleaning oven?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
Mar 23, 2011 | Kenmore Ovens
I need to know how to get a manual for a kenmore ultra bake self cleaning super capacity oven can you help me
Many Kenmore manuals are available from the Manage My Life site: http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu .
You will need the model number - there are over 9,000 ovens that come up when you search Kenmore Ultra bake self-cleaning super capacity oven. Most of the Kenmore ovens have the model and serial numbers on the front frame. (Left front of the frame on the lower oven on a dual oven model - just open the door and the panel should be visible.)
I hope this helps.
Jan 04, 2011 | Ovens
My kenmore self cleaning oven , F06 error
first try to turn the breaker off and then back on and see what happens.let me know if this helps and what is the model number?
May 10, 2010 | Ovens
I have a Kenmore Gas Oven, model # 911.30465864 and have lost the manual. I want to clean the oven, (it has self cleaning feature), but I am not sure if I can use oven cleaners in Gas Oven or not. Can...
Just use some easy off and do not use the self clean feature. Clean it the old fashioned way. Self clean ruins expensive electronics.
Feb 20, 2010 | Ovens
Self-cleaning oven doesn't work on Kenmore electric oven
I suspect the timer is involved in this process. It can be set to clean automatically. You need to set the complete time at least 2 hours after start.
Aug 27, 2009 | Kenmore Kitchen Ranges
No instructions for self cleaning oven
I turned both dials to clean and worked with the start timer and the stop timer until it engaged. I now have a clean oven again!
Feb 06, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Jan 13, 2009 | Kitchen Ranges
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
10 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
