Question about Invicta Watches
My invicta tritnite watch sundial seconds hand won't work
escapement
  • 2334 Answers
SOURCE: Invicta model 3209 watch
Your watch is fitted with chronograph movement 5040D made by Ronda (Switzerland). If you take a closer look, then you will realise that the subdial at 3 o'clock is counting seconds allready. This is your seconds dial, not the big one.
The big seconds hand actually is the chronograph hand (stopwatch) and, when activated, works together with 1/10th counter.
Follow this link and see for yourself:
http://www.ronda.ch/e/index_bedienung.html
Find movement 5040D and click on INTERACTIVE version.
Rate me, please.
Posted on Mar 25, 2009
  • 19 Answers
SOURCE: SECOND HAND - INVICTA MODEL 2692
Hi Ed,
I have been in the industry for the past 2 years as a watchmaker's assistant. So I'll see if I can help.
The larger second hand you see in this Chronograph model, using it is only available in the Chronograph mode.
How long a battery should last (if I had a dollar for everytime I've heard that one! :)
Well generally a battery should last about 2 years. It all depends on how many functions that watch has, as for a chrono the more you use that function the more the battery power it uses. I have not seen this watch but as it looks to be the 'standard' kind of format of a chronograph, just one battery would surfice.
In regards to 1/10 lap, please take the to a watchmaker as the hands need to be reset, this either can be done manually or can be done by pulling out the crown slightly (please as if you are to forcefull you will pull the crown and stem out) NOT GOOD!. if you pull it out to 'quick date change' where only the date can be changed try pressing one of the pushers and see which sub dial hands move, if that doesn't work try the other pusher.
Again if the above doesn't work, pull the crown out to time set mode (where you can adjust the time) and try the same steps as above. If this fails and it's still off, take it to a watchmaker and he/she will realign the hands for you!
Kind Regards
Shenlun
Posted on Jul 12, 2009
  • 183 Answers
SOURCE: Have an Invicta Lefty Quartz Chronograph. The
Actually the sweep arm can be set to 0 and will probably have to be every time you have the battery replaced. To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it. Make sure to set the right time and replace the crown in the time position.
Great watch!!
Posted on Sep 18, 2009
SOURCE: I just purchased an Invicta Sea Wizard Chronograph
The large second hand is actually the GMT hand for a second time zone. The second hand is the small sub dial at the 2 o'clock position. The large hand with the red arrow is the alarm time.
Posted on Jan 05, 2010
  • 5 Answers
SOURCE: the second hand on my invicta chronograph watch
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Posted on Sep 29, 2010
My invicta reserve second hand does not move
Very often not the second hand, but the seconds hand for the stopwatch. If you are sure it is, then try pulling the crown out, moving the minutes hand and then resetting the crown.
Dec 27, 2015 | Invicta Watches
The second hand won't tick
On many Invicta watches, the large hand which points towards 12 o'clock is not a second hand. It is the hand used with the stopwatch function. If yours is a chronograph, the second hand, if there is one, may be one of the three small dials on the watch face. There are a number of movements used in Invicta watches and the operating instructions can differ from movement to movement. The battery also will be different depending on the movement.
Dec 01, 2015 | Invicta Subaqua Watches
The seconds hand on my invicta subaqua reserve does not move. It only moves when I start the chronograph. I've read the instructions time after time and can not get it to work.
The hand that moves when the chronograph is working is not a second hand. It will rest at the 12 o'clock position unless you are using the stopwatch. If your Invicta has a second hand, it is one of those small dials on the watch face.
May 03, 2015 | Invicta Watches
MY INVICTA IS AN AUTOMATIC WATCH. I'VE TURNED THE CROWN SEVERAL TIMES BUT WITHIN MINUTES THE SECOND HAND STOPS
If hand winding does not work then try waving it gently from side to side for 100-200 times (yes! that is what some makers recommend).
Since self winding watches thrive on use, it is best to wear it daily to keep it functioning.
Mar 10, 2011 | Invicta Watches
I just purchased an Invicta Sea Wizard Chronograph Watch, and after taking it out of the box I noticed the large second hand does not move. The watch seems to keep time, but the scond hand is frozen in...
Nov 18, 2009 | Angel Invictas-More Styles - ELITE...
Rate me, please.
Mar 25, 2009 | Invicta 3209 Lupah Diver Watch
Invicta Gran Speedway CG second Hand reset
good after noon ! the hand of your watch is need to aline , so you need to go to the watc repairman,thank you! god bless !
Sep 03, 2008 | Invicta Speedway Collection Grand...
Watches Logo
22 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
