Question about LG LFC20760 Bottom Freezer French Door Refrigerator
Change water filter fridge side tfx24zr - LG LFC20760 Bottom Freezer French Door Refrigerator
I have a frigidaire gallery series side by side and everytime the fridge says the water filter needs to be changed now it leaks a good bit of water from the bottom of the fridge.
There is an O ring that will leak water into the overflow pan under the fridge. I'd clean the pan too to eliminate bad odors. You must shut off the water supply before changing the filter element. There is no shut off valve built into the filter or its housing.
Aug 08, 2015 | Frigidaire Refrigerators
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 26, 2011 | GE Refrigerators
Our new Samsung fridge has horrible tasting water
add water filter system to the unit ..
if it is not the water from the unit that bad then filter change might need to be done...or a new filter need to put inside.
Dec 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
My side by side whrilpool refreg
First of all, is there a reset button that needs to be pushed after changing filter? Mine has one. Check around the sides and top inside the fridge for a little button and push it in.
Is the water turned on going to the fridge?
If it was working before you changed filter, maybe the water line got kinked somewhere and no water can come through.
Also, if filter isn't reinstalled correctly, no water can come through it. Make sure the filter is not upside down and that the holder is screwed in all the way.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water gets to filter but not anywhere else
your water line that goes past the filter is clogged. use compressed air to flush out
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LFC20760 Bottom Freezer French Door Refrigerator Logo
15 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
