Question about Yamaha Audio Players & Recorders
RX-V3300 My Yamaha RX-v3300 receiver shuts off with for no reason. I'll be playing a movie or CD and all of sudden the receiver just shuts off. It will turn right back on again. What is causing it to shut off on it's own?
5 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: are there fuses i can reach with the RX-V3300
Look at the Impedance Switch on the back and make sure it is firmly in one or the other position and that it matches the impedance of your speakers.
Make sure no speaker wires are shorted to anything.
Unplug for 30 seconds and try again.
Posted on Mar 31, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do you reset Yamaha
A reset would REQUIRE you to go through EVERY setting anyway, so why don't you just go through every setting manually and leave the ones that look ok alone?
Page 52 for remote reset
Page 78 for DSP reset.
Posted on Mar 13, 2011
xe77
  • 24 Answers
SOURCE: Yamaha RX-V3300 AC outlets are
The total combined load allowed on the outlet is 100W. Make sure you are testing the outlets with a low-current device like a radio or low wattage incandescent lamp (25 or 40 W) or a night light (7 W). Also, be aware that you must have the receiver turned on for the device to work as the outlets are switched according to the main power.
If you still can't get them to work, it could be an issue with the fuse - you should take it in for service.
Posted on Mar 26, 2011
Good User
  • 87 Answers
SOURCE: Yamaha RX-V3300 Receiver shuts off on it's own.
A capacitor problem or overheat problem.
Posted on Feb 08, 2014
Feb 06, 2014 | Yamaha RX-V3300 Receiver
Left channel not working on A or B selection
The receiver came with a manual. Look in the troubleshooting section for a fix or get the manual from Yamaha on line. If the fix fails, then the left amp is defective and it is not worth the cost of repairs.
Dec 19, 2013 | Yamaha RX-V3300 Receiver
Left channel not working on a or b
Assuming everything is plugged in properly (check the manual to be sure), and you're using a setting that makes use of the left channel (try the Stereo setting to be sure), something has failed within the receiver. This type of receiver isn't designed to be user-serviced. You'll need to send it to a qualified repair shop or replace the unit altogether.
Yamaha RX-V3300 AC outlets are not working. Everything else works fine. Is there a fuse or reset button? I unplugged unit, waited >30 sec an plugged in again with no change. Thanks.
Mar 26, 2011 | Yamaha RX-V3300 Receiver
How do you reset Yamaha rx-v3300 receivers to factory settings? some of the settings got changed and we are not sure what they were
Mar 13, 2011 | Yamaha RX-V3300 Receiver
Are there fuses i can reach with the RX-V3300 Natural Sound Home Theater Receiver
Mar 31, 2010 | Yamaha RX-V3300 Receiver
Just clicks no power. Already checked for touching wires and proper cooling. This unit has worked fin in the same location for four years. Any other ideas?
I had a similar 'drop out' problem with my Yamaha RX-V3300.
Problem- Possibly loose speaker connections.
I have banana connections which I unplugged; tightened speaker terminal connections at back of receiver and then reinserted banana speaker connectors- which remedied problem. There is possibly some kind of loose connection either caused by the banana plugs or at speaker connectors at the back of the receiver, which was remedied (i.e. possibly temporarily) by reinserting the banana plugs.
I also previously thought something was wrong with the main on/off power relay which was 'dropping out' and replaced it, but then 'drop out' problem returned a few days later. I reinserted and tightened speaker connectors, which has it working again.
Dec 22, 2009 | Yamaha RX-V630 Receiver
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
15 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
