Question about AEG 7.59 cu. ft. / 215 liter Upright Freezer A75238GA
How to adjust the temperature control...is there an adjustment beside the knob
True t-49f temperature adjustment procedure?
True t 49f commercial freezer adjust temperature
If it has electronic controls, you will need the manual. On manual commercial freezers the knob is in the back of the upper unit on the right hand side. They are a good make, I have had a number of them.
http://www.truemfg.com/
Aug 13, 2015 | True Freezers
What is the standard setting defrost timer control of ts-49f
our freezer is set to defrost every 8 hours for 15 min. this seem to do the trick. we have a true t-49f reach in freezer. try this setting and see if it works for your situation.
Mar 30, 2015 | True TS-49F Stainless Steel Freezer 2...
What is the standard defrost timer control setting
Usually every 6 hours will keep the evaporator coil clear of frost. I set the time at 45 minutes per defrost. This unit has a defrost termination control that kicks it out of defrost when the coil reaches a certain temperature. The defrost timer is only a backup if the defrost control fails.
Cant find temperature control knob
Good Afternoon Friend,
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire 20.3 cu. ft. / 575 liter...
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
Location of temperature setting site
inside on the right side of the fan/coil housing. should be a black knob marked 1 - 9 the higher you set it the colder it will run. Normally set on 7 or right between 7 and 8.
Oct 25, 2011 | True 49 cu. ft. / 1388 liter Commercial...
Can the T-49F be converted from freezer to refrigerator?
Anything is possible so Yes... Although I wouldnt recommend it. The price to have a qualified technician do the job would reach very close to the cost of a new reach-in cooler and it could put a bit of a burden on the compressor. You are better off selling the freezer and purchasing a cooler with the money from the sale. It would involve one of two fairly large scale jobs. 1. The recovery of the refrigerant and installation of a CPR (Crankcase Pressure Regulator) with some wiring changes and adjustments... Or 2. The replacement of the compressor and capillary tubing.
Dec 26, 2010 | True 49 cu. ft. / 1388 liter Commercial...
I have a true freezer m/# gdm-49f s/# 5140302 ... this unit is set at -17* it runs fine when it gets to the set point turn off of course by it doesn't come back on until it reaches 0* .... I like to...
well most t stats have a differential of 5 to 7 but almost never more than ten deg so that the compressor wont short cycle .something you can check .some t stats you can adjust the differential on check if yours has that adjustment screw on the side or back of T stat if you need more help or parts e mail me at airforceac@live.com
Sep 30, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Not cold enough
Should be a thermostat with a black knob in the freezer. Usually they are marked 1-7 1 being the warmest and 7 the coldest. Usually clock wise + colder. Adjust by only 1 number per day. See how it responded the nest day. The set point is designated by a notch or arrow on the cover plate. ;)
Aug 07, 2009 | Freezers
AEG 7.59 cu. ft. / 215 liter Upright Freezer A75238GA Logo
47 people viewed this question
Top AEG Freezers Experts
Gil Shultz
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you an AEG Freezer Expert? Answer questions, earn points and help others
