Question about Epson Stylus NX400 InkJet Printer
I see ink inside my epson stylus nx400 - Epson Stylus NX400 InkJet Printer
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Leaking cartridges or Bad printer heads. New printer is cheaper than fixing.
Posted on Apr 29, 2014
Ajkill
  • 2035 Answers
SOURCE: white lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Mar 15, 2009
vegakitten20
  • 685 Answers
SOURCE: Epson Stylus NX400 printer doesn't recognize
try to unplug it and plug it back in
Posted on Mar 24, 2009
  • 400 Answers
SOURCE: epson stylus d92 won't show ink levels
hello
Download the the driver again and reinstall it.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVGcisk9ncQeIBmTUU002FxOg74o84TjGD6F5MAU003D&tc=6
Posted on May 14, 2009
cns assoc
  • 677 Answers
SOURCE: Cannot recgonize ink cartridge using Espon Stylus
Did you use Epson Genuine Cartridges?
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you. Try the excellent forum below with your similar problems.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Apr 07, 2010
  • 5 Answers
SOURCE: epson nx400 doesn't recognize ink cartridges
First of all let cartridge in the printer.... Then press Start.. it will say cartridge not recognised... then remove all cartridge (do not turn off printer).. then wait for 15 minutes...then again put cartridges in head... then press start..start...start..It will recognise on 2 to 3 tries.. Works on Epson TX210,200,410...If u want to be recognised then do not turn off printer...
Posted on Aug 26, 2010
My Epson Stylus NX400 won't recognize any of the ink cartridge after I performed a head cleaning and nozzle check option. There are still ink inside and they are original genuine ink. What should I do?
Did you remove the ink cartridge when you did the head cleaning and nozzle check, if so, did you touch the copper circuit chip on the cartridge? . . The chip is normally what tells the printer how much ink is remaining in the cartridge and if it cannot read this, it may not recognise that the cartridge is genuine and still has ink remaining inside. . . .You can try cleaning the chip with a soft dry cloth otherwise you may have to install a replacement cartridge. . . See http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469 for the User Guide showing how to replace ink cartridges for this printer.
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
My epson NX400 is telling me I need ink but not telling me which color ink I need? How can I get to give me the cartridge color?
Open the top cove and look at the ink cartridges.
Usually the ink cartridge that needs attention will be blinking.
Oct 15, 2010 | Epson Stylus NX400 InkJet Printer
Epson stylus tx110 not function and their are leakage ink inside......
If you are using non-Epson nink cartridges you may need to get a replacement set of cartridges. Secondly, the ink sponge could be full. You can try a soft cloth to remove the excessive ink. Also, take a look here for the Epson utility to correct your error. Please leave positive feedback . http://www.ssclg.com/epsone.shtml
Sep 21, 2010 | Epson Stylus NX400 InkJet Printer
How do you replace and ink cartridge in the epson nx400
This link will give you a PDF file with instructions and images on how to replace ink cartridges in the Epson NX400:
http://files.support.epson.com/pdf/nx400_/nx400_bb.pdf
Jun 03, 2010 | Epson Stylus NX400 InkJet Printer
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
I have an Epson stylus nx400 printer. I bought the ink refill kits that were recommended for it, but it's not listed on the instructions. I just want instructions on how to refill my cartridges.
Use syringre with small outlet. Fill from bottom side of ink tank. Better you don't refill ink tank. It will distort rubber seal at bottom side of ink tank. Then ink will leak. After refilling, you must reset ink counter. Do you have chip resetter?
Aug 17, 2009 | Epson Stylus NX400 InkJet Printer
I am looking for ink cartridges of Epson stylus nx400,
Here is a link to dealers in the Philippines that handle supplies:
http://www.epson.com.ph/support/dealers.shtml
Thanks for using Fixya.
Also, here is the main Philippines support page for future reference:
http://www.epson.com.ph/index.shtml
Jun 17, 2009 | Epson Stylus NX400 InkJet Printer
White lines on printed photos Epson Stylus NX400
Mar 15, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
