Question about Mitel 5212 IP Phone
What key is the super key on a mitel 5304? - Mitel 5212 IP Phone
How do I cancel a programmed key?
What platform is your phone contacted to? Mitel 3300, Mitel 5000, Mitel 2000?
Mar 13, 2015 | Mitel 5330 IP Phone
How do I change the date and time on a Mitel Superset 4025 phone system?
The time has to be changed in the programming interface of the phone system itself. You cannot change the time from any set other than a 4150 or a super console 1000. These sets can only be used to change the time on a mitel sx200 or icp. This does not work on the 3300.
Oct 09, 2014 | Mitel Superset 4025 Corded Phone...
Problem with Mitel 5212 IP Phone
Need to login to. The phone system and change it back.
Jun 06, 2013 | Mitel 5212 IP Phone
Mitel 5220 ip phone locked out
Make sure that it is a Dual Mode 5220. If it is you can use it as a SIP extension. It wiill say it on the back of the Mitel phone next to the 5220.
If it is a dual mode phone you can purchase a sip trunk from a provider and then would be able to use the phone.
When you boot up the phone hold the blue super key while the phone boots, hit the no softkey till you get to phone mode. Hit yes it will allow you to change the phone from minet to sip. This should get you started in the right direction.
Jul 30, 2009 | Mitel 5220 IP Phone
How to enter bios presario 5304
When you are starting up the PC, keep jabbing the DEL key for the BIOS screen to appear......sodeep
May 16, 2009 | Compaq Computers & Internet
Need to put clock back 1 hour
This a system change, not done on the phone, Your system administrator will need to correct this issue.
Mar 28, 2009 | Mitel 5212 IP Phone
Super set 4025 wont work
1) The phone cannot communicate with the switch. 2) Make sure your connections are good at both the jack that you plug the phone into and the block or connection coming from the Mitel switch. What Mitel Switch do you have?
Aug 17, 2007 | Mitel Superset 4025 Corded Phone...
Mitel 5212 IP Phone Logo
101 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
